8
Everything posted by 89 MJ
I’ll say the 4.0 is no high performance unit, but I think it does decent with the proper gearing. I can chirp 3rd in mine if I really want to with my 4.10s and 31s.
I’d say they’re worth grabbing, that said, it would be difficult finding another person searching for blue interior parts.
Cleaned up. And as a bonus, the center console had a brand new zip tie, a 1/2” craftsman socket, and a pack of brand new 30A fuses.
Got all of the parts cleaned up. Probably will need to do some dye work on the center console, but that’s okay because I’m pretty sure I have some left over from doing the dash. The seats, steering wheel, and column turned out very well. Little bit of vinyl repair to do on the driver’s seat, nothing major though. Until I get them in the MJ, they will make for excellent apartment furniture.
Oh yeah, it’s 182, not 177hp, I was confused earlier
That is a very cool truck.
Not quite as cool as your find, but I’m a happy camper
They will be a great addition to the truck for sure. They need some cleaning and one small repair to the vinyl, but otherwise appear darn near perfect.
Ok, I suspect that the rough idle would be an IAC or TB needing cleaning or the TPS needing adjusting. These trucks definitely are a hobby. They can be very reliable, but it usually takes a while to get them sorted out completely. And just about everyone on here has something they want to fix, update, or change on their truck, even if it appears to be done.
It should have bumped the horsepower from 173 to 177. I can’t say for sure what model year it come from, but I wouldn’t be surprised if 88 and 89 shared the same part number.
Wheel hop? Tire rubbing sound slow left turn
89 MJ replied to Co-MAAAN-cheee's topic in MJ Tech: Modification and Repairs
That toe is a big factor. You should be toed in between 1/16” and 1/8”. You might have to pull the diff cover and see if you have a limited slip or locker in that front axle for some reason. -
Montana Manche Restoration
89 MJ replied to Montana Offroad's topic in Member Projects: Your Comanches
Now we’re talking! Hopefully it works out for you!- 57 replies
- comanche
- comanche restoration
- (and 14 more)
Very nice! There’s at least one member who bought brand new AX-15, that seems like a very good route to go if you’ve got the budget for it. Otherwise, a local tech school might be able to rebuild one for you very inexpensively. The gold on gold is going to look fantastic! The Mrs did very well on the photos- 57 replies
- comanche
- (and 14 more)
And I see you got your roll bar now too. The original paint looks pretty good on it. I think I’d consider redoing the graphics, polishing the paint, and calling the exterior good. Especially with what paint costs. For the drivetrain, maybe an AX-15 and a stronger rear axle. I’m looking forward to this build in whatever route you take it.- 57 replies
- comanche
- (and 14 more)
Truck of the year poster
89 MJ replied to fiatslug87's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Unless you count Pete’s wall(s) of NOS -
That was my reaction too. The only way it could’ve been better was if the buckets were 2 door XJ or MJ ones
They’re very, very dirty, but I found a person parting out an 89 XJ with Navy interior. I grabbed the seats, center console, and tilt steering column with 3 spoke steering wheel for $200. And the steering column has a delay wiper and cruise control turn signal stalk. Pretty happy with that find. Can you tell I don’t have roommates with the parts in my living room?
I would check the alignment with a tape measure quick to make sure the toe is close. -
Does this happen at all speeds? If the tire is rubbing on something, you should see a bare metal wear mark or a black mark if it’s rubbing on something plastic. -
Emergency Brake Release With Quitar String
89 MJ replied to jamba's topic in MJ Tech: DIY Projects and Write-Ups
I believe that you need to cut a hole for it. @Gjeep might have handbrakes in his trucks, he might be able to confirm. -
All of the bolt holes should have bolts on them, I would think. Make sure there is no debris or a broken bolt in those holes. Thats a big chunk! And those vacuum lines are better than nothing
This is the way my dad taught my brother and I on the cars he has built. Put the paper in, shut the door, then try to pull it out. Works well.
