8
Everything posted by 89 MJ
If they don’t think it’ll work, you should probably disregard what I said . That said might be worth a shot if it’s not much more work.
Cruise control switch/stalk, can't find one
89 MJ replied to knever3's topic in MJ Tech: Modification and Repairs
Is it just the stalk that is screwed up with yours? Could always make a new post about it if that’s not the issue and I’m sure @eaglescout526 will have a solution. -
I would guess that it will be sufficient. My truck had AC and 4wd with the little vacuum reservoir.
That is weird. At the very least, that means it’s not a year difference being that your Eagle is older than mine.
I will also say that the AMC 15/Dana 35 cover on the Eagle does not seem as thick as the D30 front. It seemed in line with the Chrysler 8.25 and Ford 8.8 diff cover (both of which I’ve bent) in terms of thickness.
The diff covers on my Eagle D30s seemed noticeably thicker than my D30 in my MJ. Which I find odd because they were all a similar vintage. 81-84 Eagle D30 (2.72 gears) cover was as thick as my 86 Eagle D30 (2.35 gears) cover. Both of those seemed thicker than the cover on the 86 XJ D30 (4.10 gears) in my truck and thicker than the 92 and 95 YJ D30s (both 4.10 gears) that we had. I never actually measured the thickness and never had the covers off at the same time, but both my dad and I came to the same conclusion separately. The two Eagle ones I had removed at the same time, so I can confidently say that those were the same thickness, but I can’t say with 100% certainty about the other D30 covers. Leads me to believe that either Eagles had a thicker cover, which I doubt because the front crossmember protects most of it or that higher geared vehicles had a thicker cover and lower geared vehicles had a thinner cover, maybe for clearance because the ring gear would be a different width. I don’t necessarily know if I believe either of those theories though.
00-01 XJ Cast Iron exhaust manifold swap
89 MJ replied to 89 MJ's topic in MJ Tech: Modification and Repairs
Now that sounds interesting. I’m familiar with ceramic coating the exhaust and intake, but this is the first I’ve heard of that for the internals. I get why you’d want to do it though. -
Probably. Knowing all of this, if I were to change anything, it would be a ceramic coating on the HO manifold on my truck. -
Got a hat to go along with the tractor. This will probably replace my American Motors hat as my day to day hat. The AMC hat is nice, but after 2.5 years, it’s showing its age.
True. I should’ve said it, but I was talking about all headers in general there, not just for Jeeps. They always seem to leak, but I’m sure that’s a quality of the product issue too. -
Montana Manche Restoration
89 MJ replied to Montana Offroad's topic in Member Projects: Your Comanches
- 57 replies
- comanche
- comanche restoration
- (and 14 more)
Good to know. Part of the reason I’m hesitant to use aftermarket stuff is because headers are known to leak and crack and cause problems. -
Good point about the ceramic coating, I had forgotten about that. I don’t think that the wrap is worth it for the rust, like you said. On a race car, maybe, but not on a Jeep. -
And you can still see the 0.0 Litre badge over it still. Nicely done.
In an effort to help keep under hood temperatures down, has anyone considered swapping to a cast iron exhaust manifold like the 2000 and 2001 XJs have? Walker makes a pipe that way the two cats right on the manifold don’t have to be used. I would think that the cast manifold should absorb the heat of the exhaust instead of radiating it like the tubing exhaust manifold that our trucks came with. This should help with heat soak and keep engine bay temps down, I’d think. Has anyone tried something similar?
Interesting. For what it’s worth, my pattern ended up fine after testing a few times in a few places.
Multiple tailgates in NH
89 MJ replied to Dest's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Interesting, thanks! -
I think I’d definitely steer clear of Dorman for gears just because they’re probably the cheapest thing they can get.
Where’d you find that number? I knew of the 952 number being the production of 92s in 92, but never heard the total production figure for 92s. -
Pretty much -
This is the first I’ve heard of Yukon stuff being junk. I put Yukon gears in the D30 of my Eagle probably 5,000 miles ago and haven’t had any issues. Most of that is on road, but there is some off road in there. Those parts are all from probably 2022 though.
I’d be down for a set
On one hand, I like the idea of Jeep coming out with a small pickup that they’d call the Comanche. On the other hand, I’m sure they’d butcher it and make it some four door pile with no useful bed or real capability.
