eaglescout526
Administrators
    13
  1. I will definitely keep that in mind. I think I’ve got it figured. I learned last night that I was missing the solvac or idle stop solenoid, I found it on the original carb with the car and I saw why it wasn’t put back on, it’s broken in both the vacuum port and wire. What sucks is I can’t separate the two, otherwise I’d use the one I have from Chunks old set up that the PO yanked off. I found new ones on eBay I’ll probably snag to make this just a stock build. I appreciate that!! Interesting enough 86 did away with some of the stuff making emissions more simple like the air pump stuff. I’ll let you know if I run into something that im missing and can’t get new.
  2. The black one looks like it’s for cruise control to the servo. The blue one should be a atmosphere vent for the vacuum to the 4wd. I think.
  3. Emissions is making me despise living in the valley. Doing all the lines that the previous owners deleted just to get the car running.
  4. While goofing around, exploring and doing some more test driving I decided to address the rear cargo area. It one time had the cover. Decided to try an XJ cargo cover and found out that it fits perfectly!
  5. Looks like an 8. It has a curve vs being straight
  6. Decided to address the nameplate issue. My goal is to not really touch this car until I get both Jeeps assessed like Chunk and the leaf spring bushings and shackle. Little Red and the track bar. But I have a list going of what needs to be fixed on this car. Im wondering what I got myself into haha.
  7. If it’s still stock for the drive train, it should have an NP207. Unless it was swapped.
  8. It kinda varies on how tucked into the main harness it is. Best way I can say to locate it without going to my Jeep while im working is there’s a slot labeled “ign” on the fuse block itself. Should have a brown connector plugged into it that will be a black and white wire that should travel a short distance to a inline fuse connector with a fuse that should be pink in color.
  9. Underside of my hitch. Honestly this is the nicest survivor I have. Now chunk is by far the most luxurious vehicle I own and that’s how I like it.
  10. It is! And I got the wife in on it too!
  11. Thanks! i can get pictures for ya on the flaps. It looks factory. @89 MJ might know better. Yeah I noticed that….I get to join the hunt for a wiper arm that works.
  12. Yeah! Previous owner knew what he had. He was bummed to sell it but couldn’t take it with him to California. The mud flaps are definitely a nice score. I joked that I more or less bought it for the mud flaps haha.
  13. Far less of a headache to install then bleed. You’d have to get the master in and route the first hardline down and then you’d have to finagle the hardline that goes up and over the transmission with the slave cylinder and get the slave cylinder in place. And you might have to lower the transmission to get some room to do all that. Yeah just piece it together down there unless the transmission is out right now. Then I supposed you could do it as an all in one of the transmission is out.
  14. So the fuse is connected to a white with black tracer in the fuse block. Follow it and it should have a 3 or 4 amp fuse in it. I can see LEDs being an issue.
  15. Ahhh cruise control. It’s simple, yet complicated when first diving in. So the turn signal switch has nothing to do with cruise. The turn signal stalk with the cruise switches in it actually has a wire for those switches that runs down to a harness and that harness has other things plugged into it. There’s an inline fuse. I’d check that. The module isn’t know you exactly die but they are getting up there in age. Vacuum lines rot and crack, check the hardliners and rubber lines. The dump valve could’ve come out of adjustment. Located above the brake light switch. servos rarely die but they can. There’s some starting points.
  16. You absolutely did give us a fair warning! Hahaha.
  17. Well. Wife liked driving @89 MJ’s Eagle enough to wake up one morning and say “if you want an Eagle we can go get this one down in Tempe.” I thought I was dreaming or hearing things while being still groggy from waking up. But she was serious. So here we are with an Eagle. This is to be my daily daily. Retire both Jeeps and let them be fun vehicles. I’ll do pics and specs later. But for now. I wanted to start the thread.
  18. Ive been following your thread for a while. To watch the 2.8L come out and watch the 3.4L go in has been alot of fun. Love the bracket on the alt for the heater hoses.
  19. I think it’s the left most relay. Middle ought to be O2 and that third one is probably fog lamps or AC. But probably fog lamps since it doesn’t look like you have AC.
  20. I used a dryer for it’s sheet metal to create a new floor pan in my XJ. Little bit thicker and already coated in anti rust stuff. But that’s just my broke self.
  21. That car was an absolute blast to drive. Smiles per mile all the way. And he’s not kidding about people just casually asking you what car it is. Nuts!
  22. I can without a doubt say he is doing better.
