Everything posted by ejndssn
I think I found my next Comanche - PROGRESS PICS UP
ejndssn replied to XJs4Ever's topic in Member Projects: Your Comanches
so what's the plan :brows: besides taken over the comanche world...nice catch -
i intend to be in cherry hill around the end of the month will keep ya posted thanks
Sorry, it's already a done deal...Money hasn't changed hands, but we have a handshake deal , which as far as I'm concerned is just as solid... Sorry... I forgot, he is also going to help with my Engine Swap, at he has some space and a crane to help pull my old one and drop my new one in... :D That is very cool ur a dinosaur not to many of us still in existence that would do what you have done. :cheers:
I would be interested in the Bucket seat if you need to get them off your hands. just let me know what you want for them
sounds like im dragging cylinders
ejndssn replied to 603Redneck's topic in MJ Tech: Modification and Repairs
and it don't take much movement to comsume the inside of the cap :brows: look into getting that replaced and ensure when you do that the no. 1 piston is TDC. -
x2 here great score it sould like you took candy from baby. :cheers:
jus wanted to let you know that ur mean with that solder iron and probably can do that in ur sleep great skill
- 897 replies
- dana 44/8.8
- arb lockers
- (and 3 more)
Just to let you my 89 does the same and i thought that it was norm for the MJ
Engine wont run--->ALL FIXED!!!
ejndssn replied to offroader461's topic in MJ Tech: Modification and Repairs
would like to know if this is the original eng non over haul with many miles if so could the possibly that the timing chain has got some slack in it and jump a tooth or two. This similar symptom had occurred with a v6 eng I had a long time ago and I did every thing under the sun to correct :brows: when someone mention the chain may have gone slack and jumped. :hmm: Just a thought one way to check is to loosen the distributor retainer bolt so that you can move the dist left or right and see what kinda results get -
Lower Fuel Lines for MPI Conversion
ejndssn replied to xj92's topic in MJ Tech: Modification and Repairs
have you tried the http://www.discountjeepparts.com not sure that they will have want you are lookin 4 but worth a try -
my mj hates me... crank no spark
ejndssn replied to bumpy's topic in MJ Tech: Modification and Repairs
:agree: x3 faulty CPS is mostly the culprit. i always pic them as xtra's at the pic & pull and test them to ensure that i have a ready spare handy in case of an emergency get a new one first :brows: -
So I got this tranny........
ejndssn replied to jtdesigns's topic in MJ Tech: Modification and Repairs
You may need to do a search on this site.. i don't think it will work let alone last the ax-5 was design for the 4cyl and not the 4.0l it may have been behind the 2.8 v6 just some thought -
LONG POST: project virgin. Advice please
ejndssn replied to A-man930's topic in Member Projects: Your Comanches
is the setup on you tranny internal or external slave I had similar problems with the internal setuo and swap it for an external. it could the fact that the retainer on the internal slave gave way and that could be you prblem since it would be floating kinda on the input shaft. if it is the external setup I :dunno: just something to look into -
BLHTAZ have you consider a stroker :brows:
$500 MJ wrote: I am not sure what type of tranny you have, there is a difference with the main shaft that seats in the crank shaft bushing. i do believe that the internal setup of the AX-15 is a bit narrower then the later ones (external setup). just a caution :brows:
what setup do you have on the AX-15 if its internal setup and the internal slave went bad I would replace it with the one that has more metal than plastic some where here there was some pic's between the two types. If its the tranny I would consider the external setup. Good luck
here are some additional sites you may want to look into :brows: http://www.jeep4.0performance.4mg.com and here is another that i belong tohttp://autos.groups.yahoo.com/group/strokers they have a lot of data and experience. good luck BTW i have been stroked for a few years now (AP kit with a light wt crank) and If i had to do it again :hmm: .... :beerhead: hell yeah :D
X2 on the CPS
what bout emi
there has been some info IRT to Hi Idle if you do a search :brows: my problem was with the EGR valve needed replacement and the problem went away. do some research on this site so that you'll additional inforamtion to go by
here may be a start for you it appears that the wrangler 4banger is good from 87-up then you have the jeep that states 87-90 http://"http://www.precisionengine.com/rebuild-kits :dunno: whats the beef between the two. good luck
Rokhound wrote X2 I'll to that
New Member Project...suggestions?
ejndssn replied to xjcrazy09's topic in Member Projects: Your Comanches
first things first Nice Truck :cheers: 2nd that dog wanted a ride if it is your dog then i'd figured he wanted back in if not yours then you just made that dog jealous :brows: If the AX-15 is the option you know that there are two types internal and external. IMHO the external setup is the way to go. Based on your desires and not the dog's he just wants to ride. I would go and obtain the complete set tranny and t-case which ever route you auto or manual. so that the input shaft is no longer a question. The other manual tranny option is the NV3550 and second source info states that these are very good. I'll have to leave that to those that already have installed them. I believe that Pete may have one in his MJ :dunno: If just the input shaft is all that you need then some one may have one avail or the price for a new one is around buck and half or higher i believe that the 4wd site may have it for that price you be lucky at the JY and get the whole shooting match for around two bucks. sorry bout the :rant: just my dime's worth -
:jump: got mine and i hoped that lil extra helps I kinda round things up a little to help offset some of the cost. Thanks again
