Interests
4-Wheeling, Jeeps, Outdoors, Hunting
xj92's Achievements
Can Spell Comanche (2/11)
If you get a YJ bushing, it fits in the stock oem track bar, but uses a 1/2" bolt. Just FYI. I used that and drilled the hole bigger on mine. No slop as mentioned by stacks.
I want to build my MJ into a crawler. The current step in that process is to bob the bed so I have a better departure angle. I cut out a 14" section today and will hopefully get to work cleaning it up and welding it back on some time Monday. Did most of it with a 4.5" angle grinder, then used the sawzall for those places I couldn't reach with the grinder. Click the thumbnail for pics.
Drained all the fuel this morning by jumping the fuel pump relay pins, thanks for the tip.
I need to drain the fuel tank so I can drop it tomorrow, unfortunately it's at 3/4 right now. I tried a siphon tonight, but could never get it down to the fuel, there must be something there blocking it. Can I simply disconnect the fuel line at the pump, point the hose into my gas can, and fill it up? All I would have to do is turn the key I think, because that usually pressurizes the fuel system. Am I not thinking of something that would prevent from draining it this way?
Any updates on this? I'm planning to start my bed shortening project soon. I probably won't remove the bedsides or use fancy bulging bedsides, but I'm going to take around 15" behind the wheel and probably 10-12" before the wheel, depending on fuel filler and gas tank limitations, open up the wheel wells for 37s, shorten the frame to match, cut the driveshaft for the shorter wheelbase, etc. I'd love to see more if you've made any progress on it.
What mirrors are you running
xj92 replied to 91coMANche's topic in MJ Tech: Modification and Repairs
I run the 97+ on mine. I think they look clean and good. When looking for pre-97 in the junkyards, 99% of them were broken in one place or another, and post 97s just don't exist in the yards around here. I ended up ordering my mirrors from junkyards on car-part.com and paying about $40 shipped for each one. If you remove the interior door panel, you'll see a phillips head screw IIRC that holds the triangle piece in place. If you have to buy bolts to put your mirrors on, get allen-head bolts. If you get hex-head bolts, there isn't enough room for the socket to fit over the bolt head on one of the three. -
Heater Fan only turns on on high, no medium or low
xj92 replied to xj92's topic in MJ Tech: Modification and Repairs
Thx for the tip, I saw the other thread today as well with a diagram so I'll be messing with that soon. What a luxury it would be to have a fan with 4 settings :D -
The ax-4 (4-speed) or ax-5 (5-speed) that is behind your 2.5 isn't even close to being beefy enough to last behind a 4.0L, and the bellhousing pattern doesn't match up to the 4.0L either. If you swap in a 4.0L, you'll have to modify your firewall and the front radiator area of your jeep because it is an '86. The dimensions of an ax-15 are different. It is usually all bolt-in for most Cherokees, but yours might not be because it is an '86 and they didn't have the 4.0L until '87 IIRC. One popular swap is to put in a 3.4, which will mount up to your ax-5. A better option, unless you have a lot of money into the BODY of your XJ, is to simply buy one with a 4.0L/AX-15, then swap everything you want from your cherokee onto the 4.0L one and sell your current one.
Lower control arm swap question...
xj92 replied to dasbulliwagen's topic in MJ Tech: Modification and Repairs
Just buy some arms the length you need ($130 at Rusty's) or build them. The steel is cheap and the ends can be as cheap or expensive as you want. Even if you don't have a welder you could buy a $20 grinder with cutoff wheels, get everything ready, and then have a buddy weld it all up for you. 6* of caster is fine though. -
88 MJ long bed, frame rot repair
xj92 replied to LarryH88bt's topic in Member Projects: Your Comanches
If mine ever gets that bad I think I'd rather just create new frame rails from 3/16" steel, chop off the back section completely, and graft them in right behind the cab. -
I made my own stiffeners for my last Cherokee out of 4x6 box steel (1/4" wall) that I cut in half. I made the same relief cuts all the ones being sold have now and welded them up later. I also did all the holes and rosette welds. I now have an MJ instead of the XJ. If somebody offered an elegant enough product for the right price, I'd buy it. It's a pain drilling all those holes especially. Now if I get my plasma cutter before I do it next time that's another story, but with a hand drill and 4.5" angle grinder doing it yourself sucks. I also burned up my cheap hand drill with those hole saws, but didn't have any more trouble after buying a nice Milwaukee corded drill. It really did stiffen everything up. Rode much nicer after that and rocks didn't hurt it.
You could also just replace the passenger side axle shaft with one from a non-disco model. If you do this, careful when putting the new axle shaft in not to push out the seal in the pumpkin.
I have a ruffstuff cover on my rear D44 and it's been bulletproof. I made my own for the front D30 using two stock D30 covers and it has been plenty strong as well. The ruffstuff one was about $100.
Comanche won't run after 91+ upgrade
Is the camshaft profile different between '87-'90 & '91-'93? How about the crank? Will the '88 block, crank, & cam work with the '93 harness, distributor, & sensors? '90-'93 Cam Part #: 83507203 '87-'90 Cam Part #: 83500249 '90-'93 Crank Part #: 4713051 '87-'90 Crank Part #: 83504658 If that were the cause of the no start, wouldn't it blow out black smoke, backfire, whatever? It doesn't even act as if it wants to start, just sounds like the starter cranking and the engine doing nothing. When I first checked for spark it sparked normal through the gap. Last time I checked it was sparking other places due to the plug being covered in fuel & other deposits, which must have accumulated during all my attempts to unsuccessfully start. If I clean off each plug, it then sparks normally in the gap again.
