LarryH88bt
LarryH88bt's Achievements
Comanche Aficionado (4/11)
Larry i got the same problem you where having with your jeep won't rev won't do it under a load rpm go up and so do the misses what worked for you i have put new ignition sysem fuel pump and filter its super low miles so i can't imagine timing chain was it the cps or something else i thought about playin with the timing luckily my pully was clean and i found my notch in seconds had to to put the new distributor in but all that and still runnin like a wet turd
