jdog
    2
Everything posted by jdog
  1. jdog
    1JTMW6415HT126370
    BODY: MJTL61 BUILD: 3/13/1987 SELLING DEALER: BOB BANNERMAN MOTORS LTD TORONTO, ON (CA) *A6 VINYL TRIMMED BUCKET SEATS -Q8 DESCRIPTION NOT AVAILABLE ADA LIGHT GROUP AHL HEAVY DUTY INSULATION GROUP APA MONOTONE PAINT CBA STRAIGHT BACK BENCH SEAT CGX RR HEAD RESTRAINTS OUTBOARD SEATING CKA CARPET - FLOOR AND CARGO AREA CLE FRONT REAR FLOOR MATS DDJ DESCRIPTION NOT AVAILABLE DMR 3.07 REAR AXLE RATIO DSA ANTI-SPIN DIFFERENTIAL REAR AXLE ERB 4.0L I6 MPI ENGINE HCC DO NOT USE - SEE HCA JAY DO NOT USE - SEE JP, KA CLASSES JDA KPH PRIMARY SPEEDOMETER JFH TACHOMETER JGB PERFORMANCE DATA VIDEO RECORDER KQJ DESCRIPTION NOT AVAILABLE LAP SHIFT INDICATOR WARNING LAMP LBB COURTESY LAMPS LDA UNDERHOOD LAMP LMA HALOGEN HEADLAMPS LPE CARGO LAMP MBJ FRONT BUMPER MDA FRONT LICENSE PLATE BRACKET NAG DESCRIPTION NOT AVAILABLE PXF PAINT QXF PAINT SBA POWER STEERING TBB FULL SIZE SPARE TIRE WMC OPEN
  2. jdog
    1JTML6312HT033512
    Body: MJJL61 Build: 10/2/1986 Selling Dealer: Northwest Chrysler Jeep Dodge Beaverton, OR *X8 CLOTH LOW-BACK BUCKET SEATS -Q8 DESCRIPTION NOT AVAILABLE APA MONOTONE PAINT CAC LOW BACK BUCKET SEATS CGW DDQ 5-SPEED MANUAL TRANSMISSION ERB 4.0L I6 MPI ENGINE GAC TINTED GLASS WINDOWS HCC DO NOT USE - SEE HCA JJA CIGAR LIGHTER LAP SHIFT INDICATOR WARNING LAMP LMA HALOGEN HEADLAMPS MDA FRONT LICENSE PLATE BRACKET NAA FEDERAL EMISSIONS PXF PAINT QXF PAINT SBA POWER STEERING TBG COMPACT SPARE TIRE WMC OPEN 3LR DESCRIPTION NOT AVAILABLE
  3. Is there a plug under the spot where the hose connects on that black tank? It can overflow into that but unable to return it with the hose on the top. If not get a different tank
  4. I believe the temp sensor talks to the bcm, that then talks to the mirror, I can pull a wiring diagram but won't be till later today
  5. Ah man if it was a month later I would scoop this up.
  6. Which motor? More then likely in the pump
  7. They are only cheap if you don't live in a state that has adopted California emissions regulations
  8. They can, the hard part is finding the key that will work on both, they have the grooves in different places. You can also swap out to a later column if your floor shift and change the locks if you can find an xj from 93-95 iirc these use a single double cut key
  9. You'll regret it, at least by it back and part of out of sell it to someone that wants to build a truggy. Sucks big time about the accident
  10. Trans has been built, mated to the engine and stuffed into the car, full 3 in exhaust with 3.5 headers, front and rear suspension has been gone thru. E brake fixed, other things replaced. So close to the end, yet it feels so far away
  11. I get 404 error when I click on the links lol.
  12. Big Money Waste
  13. Cracked header every valve rattles oil leaks every time
  14. jdog
    CC cookbook
    Rain rain all day, guess I'll fix something inside? How's your weather?
  15. I don't but I will say good luck, this country is going away from rebuilding to replacing with junk
  16. I think it's on the compressor itself
  17. More then likely it's brake fluid from the clutch cylinder,the biggest issue is it ruins the plastic fuse box, they do sell new pins for it and there is a write up or two that explains how to do it.
  18. How's the shroud
  19. What's the voltage at the relays( round things at the edges of the fuse box)?
  20. Do you have voltage at the flashers relays? You state 3 volts, where did you Check it at? Is this a 4.0 manual? Check the intake bolts for tightness, any vacuum leaks? Performed tps adjustment? Does it do it with the cable detacted?
  21. Push it towards the cluster then press and pull yes both sides and the plastic stays with the cable
  22. Should be able to press here, but the cluster you want to use is an 86 and there was no 4.0 not sure if that cluster will work as the values might be different. You can swap speedo between them
