In the process of working out the bugs with my new Comanche. My turn signals didn’t work and upon further inspection, found the fuse panel by the clutch pedal to have had water leaking on it for some time. Unlike newer fuse panels which have plugs to connect to the harness, ours are hard wired. Are there replacement terminals available so I can remove the crusty ones and repair? I was considering putting a little muriatic acid to clean them off, but that stuff is nasty to use. Really not looking to swap the harness, but I’ll take any suggestions.
