jdog
    2
Everything posted by jdog
  1. https://youtu.be/QEdPe1SxitI
  2. jdog
    1J7FT66S5ML525344
    Not a fan of the ruined taillights
  3. Congrats on the find, welcome to the club. Be sure to add it to the registry and one of us will get you a build date and sheet.
  4. Unit is untested and will be sold in "as-is" condition umm
  5. yep normal for safety reasons, can't have you stopping in front of a semi with no brake lights
  6. this is the thread where he states it's 54
  7. With a test light check the socket for power with the pedal depressed. You either have a bad wire to that side or a bad turn signal switch
  8. Glad to hear, not sure why they labeled it trans
  9. probably warehouse
  10. welcome, nice looking truck build date 11/23/90 body jl61 APAS Monotone Paint BAPS 75 Amp Alternator BCXS Dual 700 Amp Maint. Free Batteries BGAS Power Front Disc/Rear Drum Brakes CUMS Mini Floor Console DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMMS 3.07 Rear Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass HCDS Do Not Use - See HCA JCAS 85 MPH Primary Speedometer K3GS STRIPE/BADGE/MOLDING/COLOR LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MMCS Rear Door Solid Window Insert MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF2S 18.5 Gallon Fuel Tank QG5S Hunter Green Metallic Clear Coat SCES Wrapped Steering Wheel SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 151S Zone 51-Chicago *C1 DESCRIPTION NOT AVAILABLE -Y6 Dark Sand ADLA Skid Plate Group ALN ARLA CBAP Straight Back Bench Seat CKAP Carpets - Floor and Cargo Area DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission ERH 4.0L I6 Power Tech Engine GFDA Rear Sliding Window GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZA Manual Remote Mirrors JAYA DO NOT USE - See JP, KA classes JGBP Digital Clock JHAA Var Intermittent Windshield Wipers JJAP Cigar Lighter KKSP STRIPE/BADGE/MOLDING/COLOR KWSP STRIPE/BADGE/MOLDING/COLOR K2BP STRIPE/BADGE/MOLDING/COLOR K27P Do Not Use MBJP Black Bumper MDAP Front License Plate Bracket MHAP Black Windshield Moldings MMKP Lower Grille Surround-Painted Silver PG5 Hunter Green Metallic RAAC All Radio Equipped Vehicles RAFA AM/FM Cassette Radio RCDP 4 Speakers SBAP Power Steering TBBA Full Size Spare Tire TMWA All Terrain Tires TZHP Michelin Brand Tires WJDP 15X7.0 Styled Steel Wheels WLYC All Steel Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z65P Left Front Group XIV Z82P Right Front Spring Group XI 3V3A Customer Preferred Discount
  11. They won't in Colorado
  12. Fuse good? It's the trans fuse
  13. Dunno, its strange, especially on one's that don't seem to give colors
  14. Yeah that usually uses the last eight to pull options. We get the same thing but usually can pull the Comanche codes. also you are welcome
  15. jdog
    New car questions
    Surprisingly enough a lot of cars still use keys, there's cars that still use crank windows, albeit there no mb, BMW or anything like that
  16. jdog
    New car questions
    Yes, another way to get your money All come with some kind of a alarm/security of those it will depend on the vehicle and package as to what it will do, 98% of the cars have a programmable key, most systems will have a engine immobilizer in some form or another. Doesn't stop the smart thiefs.
  17. check with your states regulations. do you mean a high performance cat? or a 90-92 factory cat?
  18. looks solid, your grill is upside down tho. Welcome
  19. Some more info about your vehicle would be a good start.
  20. this does however
  21. yes, the wing/solid windows are the same size
  22. thats marginally better, oh wait that passenger side does not line up at all
