So I am absolutely confused on this issue. I have ordered a new blower control switch (for behind the dash panel) and a new connector (in case of mine being melted) on the advice of many of you above. I have read up on adding relays around the connection at the resistor to assist in managing electric flow in the future, and had ordered parts to begin that modification. I went to work on replacing said parts above, tested the air one final time before opening up the dash, and it works!
What is happening that would cause unpredictable electric current to components some days, and no current on other days. There appears to be no correlation between temperature as I am in south FL....
