jdog
    2
Everything posted by jdog
  1. where did you get the pump? was it a pump/housig assembly? have you checked for power at the pump? if no power it could be a bad fuse link, relay, or even a bad pump Welcome, 4.0 or 2.5?
  2. if you look around you can find a cluster, i might know where one is at and can snag it, would only charge what they charged and shipping. as for aftermarket, look into a 92 or 94 can't remember what year exactly but they will have a sender in it for the thermostat housing for you to use as a spot for temp gauge, the one on the back of the head is what the light uses, but would take some adapting to get to gauge size. the oil is a lot easier, you can go off of where the sender is at, you can either tee it out or just remove the sender and install the gauge hose.
  3. yep, which one did you get?
  4. Any of them would work, I would use one of the eyelet ones as it's one less thing to crimp. The rubber is just a covering where it was spliced
  5. if your only gonna use it once or twice i'd get one of the harbor freight ones
  6. usually the easiest, but it does make it as a counter weight while trying to install torque converters should be the same yes you can do it as all one unit, might have to jack up the vehicle to get the angle for installation.
  7. jdog
    1J7FJ36L4KL532473
    Welcome
  8. jdog
    1J7FT36L5KL609944
    Welcome to the club, that is a nice looking truck.
  9. Beautiful area around Yellowstone, went a couple years ago. The dog looks like he wanted you to pet him longer. Ooh log cabins reminds me of old camp days. Looks like you had a good time and always good to get away every once in a while
  10. best manual is jeep manual, theres a downloadable link on here, i believe its in @Pete M signature
  11. jdog
    1J7FJ26L0KL541889
    build 2/17/89 body jl61 *X2 DESCRIPTION NOT AVAILABLE -YY DESCRIPTION NOT AVAILABLE ADH Heavy Duty Electrical Group ADLP Skid Plate Group AWE BA1P DESCRIPTION NOT AVAILABLE BCYP 95 Amp Battery CBAP Straight Back Bench Seat DGB All 4-Speed Automatic Transmissions DHTP Shift-on-the-Fly,P/Time T/Case EAAC All Engines EAFC all engines ERB 4.0L I6 MPI Engine GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JHA Var Intermittent Windshield Wipers JJA Cigar Lighter MDAP Front License Plate Bracket NHBP Auxiliary Transmission Oil Cooler NMCP Heavy Duty Engine Cooling PY7 DESCRIPTION NOT AVAILABLE RAAC All Radio Equipped Vehicles RAB AM/FM Radio RCDP 4 Speakers SBAA Power Steering SFDP Front Extra HD Shock Absorbers SGDP Rear Extra HD Shock Absorbers TAAC All Tires TAEA 18 LT Severe Off Road Tire Size:TBD TBBP Full Size Spare Tire TRNA P225/75R15 OWL Wrangler AT Tires WJDP 15X7.0 Styled Steel Wheels XEAP Tow Hooks XEEP Fuel Tank Skid Plate Shield XEFP Transfer Case Skid Plate Shield XEUP Front Suspension Skid Plate YGAA Without Billable Fuel YGBA 1 Additional Gallons of Gas Z01P Rear Spring Group I Z67P Left Front Spring Group XVI Z86P Right Front Spring Group XV 3AG Price Protection - Code G 4EAA Sold Vehicle 4FA Special Bid-Ineligible For Incentive 4KA Special Bid Handling 5ALA DT-Vehicle Family APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CKJS Black Vinyl Floor Covering CSRS Passenger Assist Handles DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMDS 3.55 Rear Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror JAAS Instrument Panel JAZS DO NOT USE - See JP, KA classes JBFS Instrument Panel Black Bezel JCAS 85 MPH Primary Speedometer JKBS MOPAR Hood Lock KDCS DESCRIPTION NOT AVAILABLE K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS 35 Tire Body Color Fender Flares MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares NAAS Federal Emissions NBAS Underground Calibration NBKS EVAP Control System NDAS Catalytic Converter NF2S 18.5 Gallon Fuel Tank QY7S DESCRIPTION NOT AVAILABLE SCBS Steering Whl TBMS Tire Carrier Winch XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1ALS U.S. State/Local Bid 135S Zone 35-Washington 4FMS Fleet Option Editor
  12. Look into getting a REM it'll help in telling what sensors are doing what
  13. jdog
    SWB Roll Bar
    iirc last one sold on here was 700, all depends on area and whats someone is willing to pay
  14. Could be, do cruisers tips, check the c101 connector for corrosion. Do a full tune up wires, plugs, cap and rotor
  15. jdog
    CC cookbook
    Here's a late picture of the kaluha pork
  16. Does it come with tumblers?
  17. jdog
    CC cookbook
    They usually are, haven't had one I didn't like yet
  18. Being em to me, also I might have a good pair
  19. Googleing is hard lol, hope for progress soon
  20. jdog
    CC cookbook
    Made some Bierocks tonight, and because i had to get cabbage for it ill be making kahlua pork tomorrow
