jdog
    2
Everything posted by jdog
  1. in mobile the option for messenger is gone with the update
  2. Have you recently changed the cluster out? If not then your wire for the gauge is grounded out somewhere
  3. Amazon has a few
  4. That looks really clean
  5. i would think so, I guess base/fleet vehicles
  6. Which style window do you have, 3 pane or 4?
  7. Sounds good for a motor that's been sitting, bet if you squirt a drop of oil in them the numbers will jump up and even out
  8. Let me clarify what year jeep is this prop valve supposed to go to, did you order it for a 90? & pictures of the flair
  9. what year prop valve? they went from a standard to a metric fitting, still would like pictures when you get a chance
  10. pictures of flairs
  11. Could be just stuck, are you pulling straight back? Are you sure that the screw is out all the way, iirc it's a long screw
  12. I think I have one of your interested
  13. Once those have been verified as good look into amp draw and how to check for amp draw, only other questions I have is which radio fuse did you pull?
  14. I forgot to click on your name
  15. Correct, there is a hose that goes between that and the airbox used for colder climates to heat the air in the airbox
  16. The two circled should be connected together @eaglescout526 can you assist with a part number?
  17. This is just a heat riser
  18. Welcome, congrats on finding a Comanche. Pictures are worth a thousand words As for the brakes, that could be a few things, if you pump on them does it raise the pedal at all? Has anything been replaced? I'm betting you have air in the system and it wasn't properly bleed.
  19. https://www.ebay.com/itm/1x-CERAMIC-H4-HEADLIGHT-RELAY-WIRING-HARNESS-2-HEADLAMP-LIGHT-BULB-SOCKET-PLUGS/290975680907?epid=25018508875&hash=item43bf80898b:g:YUMAAOSwxzBc2-B9 or https://www.ksuspensionfab.com/store/p6/H4_Upgraded_Headlight_Harness.html#/
  20. Start a build thread and then send 89 mj a message stating you would like to be cotm
  21. Ours looked like that yesterday, today is rain /snow, hopefully it helps the fires here
  22. Caddilac has taillight connectors
  23. You are correct but we get the Vin info from Chrysler, what I was saying is Chrysler screwed it up when they inputted the data into their system that they recieved from amc
