jdog
    2
Everything posted by jdog
  1. have you done cruisers tips? the solid turn signal is a bad ground, most likely in the front end. when you say gsuges don't work, which gauges? which cluster? have you check the fuse? hows the fuse box?
  2. depends on year, model, plans for the vehicle,
  3. jdog
    1JTML6313JT069277
    body: jl61 build: 10/23/87 *X2 DESCRIPTION NOT AVAILABLE -H9 AGC AHL Heavy Duty Insulation Group APA Monotone Paint BCQ 750 Amp Maintenance Free Battery CBA Straight Back Bench Seat CGW DDQ 5-Speed Manual Transmission ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GEC Front Left Side Sliding Window GSC Right Black Mirror JFH Tachometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter LAP Shift Indicator Warning Lamp LMA Halogen Headlamps MDA Front License Plate Bracket NAA Federal Emissions NHQ Transmission Heater NMB Standard Duty Engine Cooling PWB paint code QWB Paint code SBA Power Steering SUA Tilt Steering Column TBG Compact Spare Tire WMC Open
  4. Congrats, this build really took off this year and looks good
  5. That sucks. Hoping for the best
  6. Don't we all
  7. I would say probably uneaqual air/fuel mixture as to why they aren't showing lean you have got me, maybe its only lean during certain times, ie full throttle or high revs
  8. Yep to check it turn the fan on in vent or heat mode and see if it makes noise, if not then it's probably the a/c clutch, or a loose belt
  9. bad hvac fan, bad clutch
  10. have you changed them since it was converted to lpg? how many miles on the plugs? how much more build up?
  11. Looking good, rust sucks
  12. build a fort with them
  13. 89
  14. jdog
    Face mask
    Anyone have a Recommendation for a good breathable face mask? Doesn't look like this stuff is going anywhere
  15. Have you tried seeing if it will move in 4lo
  16. Computer is under the dash passenger side, but it doesn't control park. If there is no issue with park what are the symptoms?
  17. Was the convertor fully seated when you installed the trans? It sounds like either a convertor issue or a bad valve body Is it 4wd, is your tcase in gear?
  18. Welcome to the club I'm not sure about a 91 manual check the connector on the side of the steering column, it is the ignition switch. also perform cruisers tips, link in my signature. also fill out your signature with your truck details to aid and assist us in helping you with your truck
  19. thats pretty neat, and a great way of doing it
  20. Must be talk radio
  21. How's everyone doing? I know the fires are still going on, @Pete M how's your grandma? Everyone staying health I hope.
  22. On mobile all I have is sound no videos
