2
Everything posted by jdog
if you wanna know how screwed up they are, according to chrysler this truck was sold in switzerland
body: JL61 Build date: March 3, 1987 *X1 DESCRIPTION NOT AVAILABLE -Q8 DESCRIPTION NOT AVAILABLE APA Monotone Paint CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating DCK DESCRIPTION NOT AVAILABLE EPD DESCRIPTION NOT AVAILABLE HCC Do Not Use - See HCA LAP Shift Indicator Warning Lamp LMA Halogen Headlamps MDA Front License Plate Bracket NAA Federal Emissions PXF DESCRIPTION NOT AVAILABLE QXF DESCRIPTION NOT AVAILABLE RAF AM/FM Cassette Radio TBG Compact Spare Tire WMC Open
https://1001albumsgenerator.com/
Problem with Vacuum on the Heater & Deforster
jdog replied to Top C's topic in MJ Tech: Modification and Repairs
unfortunately no as its not pressure you are losing but vacuum. you will have to look, listen and inspect it all, you could also smoke test the lines -
only thing i see atm is that rear window, but they suck to pull.
nah i'm gonna pass, is that black interior? you guys gonna grab that rear window?
hate to disagree, but if its the blue dot its in the sidewall and doubt anybody will patch it.
We had a Chrysler in the other day that required the engine/trans to be pulled to replace a rear hvac line.
Have you performed cruisers tips?
Headlight harness relay upgrade... with DRLs?
jdog replied to gogmorgo's topic in MJ Tech: Modification and Repairs
Nope only if it went to Canada, even then it sounds like it didn't and he's trying to figure out how to get them to be on -
in Kansas at a dealer
jdog replied to jdog's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
who knows, it also looks like a 80s ford radio in it -
can't help with the coil situation tho, good luck
build date:5/6/87 body: tl61 *A6 Vinyl Trimmed Bucket Seats -Q8 DESCRIPTION NOT AVAILABLE APA Monotone Paint CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating DCB Open EPD DESCRIPTION NOT AVAILABLE GAC Tinted Glass Windows GFD Rear Sliding Window HCC Do Not Use - See HCA JJA Cigar Lighter LAP Shift Indicator Warning Lamp LMA Halogen Headlamps MDA Front License Plate Bracket MWF Adjustable Roof Rail Crossbars NAA Federal Emissions PXF DESCRIPTION NOT AVAILABLE QXF DESCRIPTION NOT AVAILABLE TBG Compact Spare Tire WMC Open 3LR DESCRIPTION NOT AVAILABLE
https://www.facebook.com/marketplace/item/4494227560647966/ @Minuit do your worst, this thing is bad
This Vehicle needs a 02 sensor recall build date 11/17/86 body: jl62 *X1 DESCRIPTION NOT AVAILABLE -YY DESCRIPTION NOT AVAILABLE ADA Light Group ADL Skid Plate Group APA Monotone Paint BCQ Maintenance Free Battery CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating DGW 4-Spd. Automatic Transmission DMR 3.55 Rear Axle Ratio ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GFD Rear Sliding Window GPB Tow Mirrors HCC Do Not Use - See HCA JHA Var Intermittent Windshield Wipers JJA Cigar Lighter LBB Courtesy Lamps LDA Underhood Lamp LMA Halogen Headlamps LPE Cargo Lamp MDA Front License Plate Bracket NAA Federal Emissions NFA 23 Gallon Fuel Tank NHB Auxiliary Transmission Oil Cooler NMB Standard Duty Engine Cooling PXH DESCRIPTION NOT AVAILABLE QXH DESCRIPTION NOT AVAILABLE SBA Power Steering TBG Compact Spare Tire TBL Inside Mounted Spare Tire WJD 15X7.0 Styled Steel Wheels Z1B GVW/Payload Rating
Thank you
colorado auto and parts (they have a really cool plymouth as the mascot) https://coloradoautoandparts.com/p-r-t/ lkq https://www.lkqpickyourpart.com/ u pull and pay https://upullandpay.com/denver/search-inventory/ Martins supply https://www.martinsupplyautoparts.com/ @Pete M this is the one you went to
That thing looks clean build date 11/15/91 body tl62 *C1 DESCRIPTION NOT AVAILABLE -SA Charcoal ALAP BARP 90 Amp Alternator BCDP 500 Amp Maintenance Free Battery CBAP Straight Back Bench Seat CKAP Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions DHTP Shift-on-the-Fly,P/Time T/Case ERH 4.0L GFD Rear Sliding Window GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZP Manual Remote Mirrors HAA Air Conditioning JHAP Var Intermittent Windshield Wipers JJAP Cigar Lighter KERP DESCRIPTION NOT AVAILABLE MBJP Black Front Bumper MDAP Front License Plate Bracket MHAP Black Windshield Moldings MMKP PB8 RAAC All Radio Equipped Vehicles RAFP AM/FM Cassette Radio RCDP 4 Speakers SBAP Power Steering SCGP Wrapped Steering Wheel TMWP Tires TZAP Goodyear Brand Tires WJNP 15 Aluminum Wheels WLZC All Aluminum Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z59P Left Front Spring Group Ix Z78P Right Front Spring Group VIII 2TCA Customer Preferred Package 2TC 26C Customer Preferred Package 26C 3VNA Customer Preferred Discount 4HA Special Scheduling Condition I 4M1P Retail to Bid Diversion Tracking 4UA SCA Tissue North America LLC APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DMDS 3.55 Rear Axle Ratio DRJS 175MM Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass JAZS DO NOT USE - See JP, KA classes JCAS 85 MPH Primary Speedometer KWRS STRIPE/BADGE/MOLDING/COLOR K3ZS STRIPE/BADGE/MOLDING/COLOR LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MMCS Rear Door Solid Window Insert MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF5S 23 Gallon Fuel Tank QB8S SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail 135S Zone 35-Washington
Needed a zip up, thank you for the reminder
https://denver.craigslist.org/cto/d/littleton-1989-jeep-comanche/7220693551.html
