Rochikus
Rochikus's Achievements
  1. Been a crazy few days at work, but finally there is the picture
  2. It got dark so I packed it up for the day, I’ll snap a pic tomorrow, but no I’ve never had to hold the throttle open to start it or keep it running. They’ve all got their random gremlins, but this is the first mechanical issue I’ve ever had with it. It’s fired up without fail and ran wonderfully without question every time prior to this.
  3. It actuates when finished cranking. I don’t know if it’s supposed to be smooth, or if more of a click-click-click is normal, but it’s always done it
  4. Sorry for the delay. I should’ve mentioned it in the main post, the injector is definitely firing. I didn’t test it exactly, but I can hear it and see fuel spray. I also verified I’m not getting any fuel leaking from that hole.
  5. I’ve got something going on that is confusing the hell out of me. It might be something stupid that I haven’t thought of, but I really don’t know. 1987 2.5l TBI 4sp, between work and whatever else, it’s been dead about 4 months now. Started initially then died after about 30 seconds. Then stayed as a crank no start. After my basic tests, I’ve got fuel and spark, and my timing is good. I don’t know why I suspected something with fuel, but if I unplug the fuel relay and pour a small amount of gas into the throttle body it’ll run for a few seconds perfectly fine. Fast forward to now, I noticed if cranked too long gas starts free pouring out of the exhaust and spark plugs get all fouled up. After that, when the plugs are cleaned up, I can disconnect the fuel lines completely and it’ll run for several minutes, until wherever it’s getting the fuel from runs out. I did a fuel pressure test on crank and get about 13-16 psi. I have changed a few things but kind of wanted to start at a baseline. I desperately need help, because I cannot figure it out. Anything would be appreciated immensely.
  6. Here it is. Sorry I got busy lol
  7. Then it was custom made. The picture I’ve got doesn’t really describe it, I can take one later from the back. It sticks out maybe 4-6” from the taillight housing
  8. Can’t speak to the bumper, but you probably right. PO had a very clearly aftermarket one on. No a/c, or no power steering either haha.
  9. Oh yeah, I mean, I knew it was as base as it could get. No 12v plug, no clock, had the dummy gauges, the works for a base lol
  10. Yeah I was hoping for a nice long one too. Oh well. I’ll give those spots a check when I get home, I’ve already got a good amount of the interior taken apart doing the headlight switch.
  11. I noticed I forgot to do this and I wanted to haha 1987 sportruck. 2.5l, 4sp manual, 4x4. Nothing notable, besides the floor pans are terrible and good ol’ renix wiring. It runs and drives, and I’m terrible with posts. Located in NW Indiana.
