jdog
    2
Everything posted by jdog
  1. jdog
    1JTWL6570GT216125
    Anybody want anything off this thing? If there is anything left
  2. jdog
    1JTWL6570GT216125
    Just set down at the local yard
  3. https://youtu.be/oNxMXDIzSCI
  4. Slow Cast iron or non-stick
  5. jdog
    1JTML63P6JT023768
    needs a 02 sensor recall build 08/14/87 body: jm61 *X4 -YY AGJ APA Monotone Paint CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating CKA Carpets - Floor and Cargo Area DDQ 5-Speed Manual Transmission ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GFD Rear Sliding Window GPB JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K60 STRIPE/BADGE/MOLDING LAP Shift Indicator Warning Lamp LMA Halogen Headlamps MBJ Black Front Bumper NAA Federal Emissions PE4 Colorado Red QE4 Colorado Red RAB AM/FM Radio SBA Power Steering SCE Steering Wheel TBG Compact Spare Tire WJN 15 Aluminum Wheels 3LX
  6. hickory conventional or synthetic oil
  7. nah just go with this https://www.jegs.com/i/Ford-Performance/397/M-6007-A50SC/10002/-1 points are good as long as you set and adjust/change them out.
  8. gear jamming all the way smokers window or solid
  9. Pencil Apple or Android
  10. Yep to both of your questions Either I or @eaglescout526 will get you some info
  11. steak all day red or white chile
  12. heat atm vhs or dvd
  13. Dp Carhartt or walls
  14. 456 Bttf or Indiana Jones
  15. Brookie Gremlins or furbies
  16. Winch Leto or nickleson for joker
  17. I don't think they had a fuse on the lights, maybe a breaker. I'd suspect either a bad switch or a bad high beam switch Probably the latter
  18. exo 2wd or 4x4
  19. how many other skids are on it? I see you got the front one with it.
  20. I can understand that, I wouldn't mind having one but the time to by them cheap was before my time
  21. did you try switch the middle two? was never a fan of the ford style starter relay
  22. picture of starter relay
  23. jdog
    1JTMW6451JT199731
    gotcha Vehicle needs a 02 sensor recall Build Date:5/7/88 Body: ts61 *Q7 Cloth Low-Back Bucket Seats -SA Charcoal AGD APA Monotone Paint CAC Low Back Bucket Seats CGW CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console DDJ Manual Transmission ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GFD Rear Sliding Window GSC Right Black Mirror JFH Tachometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K60 STRIPE/BADGE/MOLDING LAP Shift Indicator Warning Lamp LMA Halogen Headlamps LNJ Front Fog Lamps MBJ Black Front Bumper MCA MCB NAA Federal Emissions PX6 Paint Code QX6 Paint Code RAB AM/FM Radio SBA Power Steering SCG Leather Wrapped Steering Wheel SUA Tilt Steering Column TBG Compact Spare Tire WJH 15X7 Aluminum Wheels 3LY
  24. build date: 11/5/90 body: tl62 *C1 DESCRIPTION NOT AVAILABLE -SA Charcoal ALA ALK BAFP 130 Amp Alternator BCYP Battery CBAP Straight Back Bench Seat CKA Carpets - Floor and Cargo Area DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission ERH 4.0L I6 Power Tech Engine GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAY DO NOT USE - See JP, KA classes JGBP Digital Clock JJAA Cigar Lighter MBJA Black Front Bumper MDAP Front License Plate Bracket NAE California Emissions PS7 Dark Silver Metallic SBAA Power Steering TBB Full Size Spare Tire TPF P205/75R15 BSW All Season Tires TZHP Michelin Brand Tires WJK 15X6.0 Styled Steel Wheels WLYC All Steel Wheels YAA Build To U.S. Mkt. Specifications YEP Manuf Statement of Origin YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z58P Left Front Spring Group Viii Z77P Right Front Spring Group VII 1AA U.S. Dealer Retail 3VQA Customer Preferred Discount 4XU Aug. Retail to Fleet Reassignments APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes CUMS Mini Floor Console DMMS 3.07 Rear Axle Ratio DRJS Dana M35 Wide Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass JCAS 85 MPH Primary Speedometer KWXS DESCRIPTION NOT AVAILABLE K3ZS STRIPE/BADGE/MOLDING/COLOR LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS 35 Tire Body Color Fender Flares MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares NBKS EVAP Control System NF5S 23 Gallon Fuel Tank QS7S Dark Silver Metallic Clear Coat RA8S Delete Radio SCES Steering Wheel SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBMS Tire Carrier Winch XBSS Pickup Box Z1AS GVW/Payload Rating 171S Zone 71-Los Angeles 4AFS
