2
Everything posted by jdog
40$ unless you can get um to do a package deal Steer Colmn No Tilt W/Whl Car $31.99 $4.99
Junk yard tip use hood release cables to cut out the windows (just make sure they are off of a ford or gm)
Build date: 1/25/88 Body:jm62 *X1 DESCRIPTION NOT AVAILABLE -YY DESCRIPTION NOT AVAILABLE ADL Skid Plate Group AGJ Driver Assistance Group AGP DO NOT USE - SE application APA Monotone Paint CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating CKA Carpets - Floor and Cargo Area CLE Front Rear Floor Mats DDQ 5-Speed Manual Transmission ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GFD Rear Sliding Window GSC Right Black Mirror JAY DO NOT USE - See JP, KA classes JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K60 STRIPE/BADGE/MOLDING LAP Shift Indicator Warning Lamp LMA Halogen Headlamps MBJ Black Front Bumper MDA Front License Plate Bracket NAF High Altitude Emissions PWB PAINT QWB PAINT RAF AM/FM Cassette Radio SBA Power Steering SCE Steering Wheel SUA Tilt Steering Column TBB Full Size Spare Tire WJN 15 Aluminum Wheels 3LW DESCRIPTION NOT AVAILABLE
Good news everyone Pancake or waffles
buy or trade whichever is easier
yeah i got em, top, bottom, and side pieces
bone in real butter or margarine
Black grill trim
I've got some ill sell you they came off mine when I went to chrome
what all do you want to swap?
You don't lose em? I can never keep any more then a month with out losing it
So you want to convert to 4wd from a 4.0 to a 2.5, short answer no The gears are different in the front axle, if the trans is factory in the 4.0 its crap the trans you want is a ax5. I don't think the 4.0 trans will bolt up but I'm not 100%
Neither Game show or news
not the chapstick?
bump wallet, keys, and either cold steel recon tanto blade or a kershaw blade and a phone
BUILD DATE:11/10/86 BODY: JM61 *X1 -YY AGJ Driver Assistance Group APA Monotone Paint CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating CKA Carpets - Floor and Cargo Area DGW 4-Spd. Automatic Transmission ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GEC Front Left Side Sliding Window GFD Rear Sliding Window GPB MIRRORS HAA Air Conditioning HCC Do Not Use - See HCA JHA Var Intermittent Windshield Wipers JJA Cigar Lighter LMA Halogen Headlamps MBF Bright Rear Bumper MDA Front License Plate Bracket MFD Bright Grille MWF Adjustable Roof Rail Crossbars NAA Federal Emissions PX6 PAINT CODE QX6 PAINT CODE RAB AM/FM Radio SBA Power Steering SCE Steering Wheel SUA Tilt Steering Column TBG Compact Spare Tire TBL Inside Mounted Spare Tire WJM 15X7.0 Chrome Wheels 3LT
Rockies Brownies or cake or pie
peace ham or turkey
Vehicle has a open recall for 02 sensor BUILD: 4/8/89 BODY: TL61 *B1 -Q8 BAYP 105 Amp Alternator BCYP 95 Amp Battery CBAP Straight Back Bench Seat DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission EAAC All Engines EAFC ERB 4.0L I6 MPI Engine GRVP Left Manual Mirror HAA Air Conditioning JJA Cigar Lighter MBJ Black Front Bumper MDA Front License Plate Bracket PQ9 PAINT RAAC All Radio Equipped Vehicles RAB AM/FM Radio RCDP 4 Speakers SBAA Power Steering TAAC All Tires TNCA Tires YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z58P Left Front Spring Group Viii Z78P Right Front Spring Group VIII 5ALA DT-Vehicle Family APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CKJS Black Vinyl Floor Covering CSRS Passenger Assist Handles CUMS Mini Floor Console DMMS 3.07 Rear Axle Ratio DRJS Dana 35 Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror GUAS Open JAAS Instrument Panel JAZS DO NOT USE - See JP, KA classes JBFS Instrument Panel Black Bezel JCAS 85 MPH Primary Speedometer JKBS KDCS K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS 35 Tire Body Color Fender Flares MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares NAAS Federal Emissions NBAS Underground Calibration NBKS EVAP Control System NDAS Catalytic Converter NF2S 18.5 Gallon Fuel Tank QQ9S PAINT SCBS Steering Whl SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TADS TBCS Compact Spare Tire TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels WMCS Open XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail 161S Zone 61-Atlanta
Welcome back, factory tilt column for a floor shift/manual is the same as a cherokee. A bit harder to find if a column shift. Does not look bad, be sure to add it to the registry and we will get a build sheet. Ps your grill looks upside down
Or the master dyi list in Pete's sig
Stalling Unless Plugged Into Ignition Coil?
jdog replied to Boltjd's topic in MJ Tech: Modification and Repairs
Will just depend, these things have had melted wires at the ignition switch, bad switch or blown fuse links. If it's the last gotta figure out why it blew -
Hey that's how my cat looked
