2
Everything posted by jdog
Pretty sure he wants the spring clamps
be careful with the additive, they stopped the zinc content as they ruin cats
Theres a box of gloves in the truck, probably not the best place
BUILD: 12/13/89 BODY: TL61 *Q7 Cloth Low-Back Bucket Seats -SA Charcoal ADAA Light Group ALR ARM Radio AM/FM Cassette BA1P DESCRIPTION NOT AVAILABLE BCYP 95 Amp Battery CACP Low Back Bucket Seats CDBP Reclining Front Seats CKAP Carpets - Floor and Cargo Area CUFA Full Length Floor Console DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission ERB 4.0L I6 MPI Engine GFDP Rear Sliding Window GNBP Driver Side Illuminated Sun Visor GNCP Sun Visors w/Illum Vanity Mirrors GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZA Manual Remote Mirrors HAA Air Conditioning JAYP DO NOT USE - See JP, KA classes JGBP Digital Clock JHAA Var Intermittent Windshield Wipers JJAP Cigar Lighter KLHP DESCRIPTION NOT AVAILABLE K2BP STRIPE/BADGE/MOLDING/COLOR LAJP Headlamps On Warning Chimes LBBP Courtesy Lamps LBDP Ash Tray Lamp LBEP LDHP U/Hood Lamp LHDP Headlamp Off Time Delay LNJP Front Fog Lamps MBJP Black Front Bumper MCAP MDA Front License Plate Bracket MFKP Body Color Grille MHAP Black Windshield Moldings MMKP Lower Grille Surround-Painted Silver PW7 Bright White Clear Coat RAAC All Radio Equipped Vehicles RAFA AM/FM Cassette Radio RCDP 4 Speakers SBAA Power Steering SCGP Leather Wrapped Steering Wheel SUAA Tilt Steering Column TAAC All Tires TRMA Tires WJHP 15X7 Aluminum Wheels WLZC All Aluminum Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z58P Left Front Spring Group Viii Z78P Right Front Spring Group VIII 5KRA Midland Corporation APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes CSRS Passenger Assist Handles DMMS 3.07 Rear Axle Ratio DRJS Dana 35 Wide Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror JCAS 85 MPH Primary Speedometer K3WS STRIPE/BADGE/MOLDING/COLOR LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps MB1S Black Front Bumper MMCS Rear Door Solid Window Insert MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF2S 18.5 Gallon Fuel Tank QW7S Bright White Clear Coat SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail 166S Zone 66-Orlando
BODY:TM61 BUILD:6/24/88 *X1 DESCRIPTION NOT AVAILABLE -Q8 DESCRIPTION NOT AVAILABLE AGJ Driver Assistance Group APA Monotone Paint BCQ Maintenance Free Battery CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating CKA Carpets - Floor and Cargo Area DCB Open EPD DESCRIPTION NOT AVAILABLE GAC Tinted Glass Windows GFD Rear Sliding Window GSC Right Black Mirror HAA Air Conditioning JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K60 STRIPE/BADGE/MOLDING LAP Shift Indicator Warning Lamp LMA Halogen Headlamps MBJ Black Front Bumper MDA Front License Plate Bracket NAA Federal Emissions NMB Standard Duty Engine Cooling PB3 QB3 RAB AM/FM Radio SBA Power Steering SCE Steering Wheel TBG Compact Spare Tire WJD 15X7.0 Styled Steel Wheels 3LX DESCRIPTION NOT AVAILABLE
Just watch the year you pull out from
Just don't use wd40 fire balls happen
Yep that's what the strap was for, still didn't go
one arm was in, ratchet strap on drivers knuckle and jack under it just wouldn't line up, stock arm went right back in no issue
yep they would lock up the engines, spray them so you knew they were c4c and jy made millions
thats what mine looked like jacked up and off of the stands. but no matter how much i tried the bolt will not line up
this is where it hits, not on the upper but the lower. not sure what they changed on the axles or why mine is different then majority. and i don't have a lift yet.
yeah that's were i'm at so looking for tube style arms
my side show it as either a journey or a 86 unknown with no other info but the info should be posted within the week when eaglescout returns
no problem been to a few yards
if its anything like the ones here i usually count it as i paid for it with the admission fee
if you get the transfer case it will be $389.93
I hate yards like that, they try to nickle and dime you, but itll be the death of them eventually crossmember - 15.50 trans mount - 10 shift knob - 2.09 Transmission - 90 + 30 core gls vent assbly- 22 glass door - 20 rear glass -34 strg column - 36 + 5 core + sales tax of - 7.25% = 283.77 That if that is all you get with out someother tax or fee that want to add. or if you find anything else you want it also doesn't include the transfer case yes the boots should fit
couldn't rotate it the way to get em to line up also wasn' really wanting to grind on the axle bracket
yep both ends would fit, only tried one side, did not disconnect the track bar. and center of the axle thank you for the suggestions.
After getting the arms to install body side, the axle side would not line up, it would hit the mounting brackets of the lower control arm and keep it a half-inch from lining up. don't think the axle twisted cause the old one went right back in same as strokermjcomanche in
also what all is on the list of items you are grabbing? it all depends on the yard and the checker/register person, some days they don't care about small stuff, some will charge you for every little thing
with wheel, the only option they had was car
Oh wise and knowledgeable CC folks I'm looking for options for lower control arms. I am unable to use GC arms for some strange reason, so what brand do you recommend. what is good and who do i stay away from? this is for a short arm. not looking for long arm yet
VIN: 1J7FT36S0ML568116 BUILD:12/20/90 BODY: TL61 APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DMDS 3.55 Rear Axle Ratio DRJS Dana 35 Wide Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass JAZS DO NOT USE - See JP, KA classes JCAS 85 MPH Primary Speedometer K3LS STRIPE/BADGE/MOLDING/COLOR LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MMCS Rear Door Solid Window Insert MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF2S 18.5 Gallon Fuel Tank QB8S SCES Steering Wheel SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail 166S Zone 66-Orlando *B1 DESCRIPTION NOT AVAILABLE -SA Charcoal ALN ARLA BAFP 130 Amp Alternator BCYP Battery CBAP Straight Back Bench Seat CKAP Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions DHTP ERH 4.0L I6 Power Tech Engine GFDA Rear Sliding Window GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZA Manual Remote Mirrors HAA Air Conditioning JHAA Var Intermittent Windshield Wipers JJAP Cigar Lighter KKSP STRIPE/BADGE/MOLDING/COLOR KWSP STRIPE/BADGE/MOLDING/COLOR K2BP STRIPE/BADGE/MOLDING/COLOR K27P Do Not Use MBJP Black Front Bumper MHAP Black Windshield Moldings MMKP PB8 RAAC All Radio Equipped Vehicles RAFA AM/FM Cassette Radio RCDP 4 Speakers SBAP Power Steering TMWA All Terrain Tires TZHP Michelin Brand Tires WJDP 15X7.0 Styled Steel Wheels WLYC All Steel Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z58P Left Front Spring Group Viii Z78P Right Front Spring Group VIII 3V3A Customer Preferred Discount 4HA Special Scheduling Condition I
