jdog
    2
Everything posted by jdog
  1. no worries, classifieds open up at ten posts. good luck with your search
  2. @neohic @Eagle @Pete M Please move to classifieds
  3. ok, verify the battery is good, just because its new doesn't mean its good, you'll have to do a amp draw test to figure out whats staying on. another thing could be either a mis-adjusted ignition switch or a bad key tumbler thats allowing the key to be removed in the acc. position.
  4. with 10 posts now you should be able to post in the wanted section/ look in the classifieds
  5. OK let's clear this up, what exactly are you wanting to know, is it the battery dies or is it the vehicle doesn't start?
  6. Not turning off, pull the bulb and see if the draw goes away
  7. @Pete M @neohic@Eagle Please move to proper Area Welcome, hard to say with that info and no pictures
  8. jdog
    1J7FJ26SrNL192909
    Correct VIN: 1J7FJ26S4NL192909 BUILD:2/4/92 BODY:JL61 APAS Monotone Paint BAPS 75 Amp Alternator BCCS Maint. Free Battery BGAS Power Front Disc/Rear Drum Brakes CUMS Mini Floor Console DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMMS 3.07 Rear Axle Ratio DRJS Dana 35 Wide Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass HCDS Do Not Use - See HCA JCAS 85 MPH Primary Speedometer KWRS STRIPE/BADGE/MOLDING/COLOR K3ZS STRIPE/BADGE/MOLDING/COLOR LAPS Shift Indicator Warning Lamp LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MMCS Rear Door Solid Window Insert MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF2S 18.5 Gallon Fuel Tank QE4S Colorado Red SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBCS Compact Spare Tire TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 172S Zone 72-Portland *C1 DESCRIPTION NOT AVAILABLE -SA Charcoal ALAP CBAP Straight Back Bench Seat CKAP Carpets - Floor and Cargo Area DBBC All Manual Transmissions DDQ 5-Speed Manual Transmission ERH 4.0L I6 Power Tech Engine GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZP Manual Remote Mirrors JAY DO NOT USE - See JP, KA classes JHAP Var Intermittent Windshield Wipers JJAP Cigar Lighter KERP DESCRIPTION NOT AVAILABLE MBJP Black Front Bumper MDAP Front License Plate Bracket MHAP Black Windshield Moldings MMKP Lower Grille Surround-Painted Silver PE4 Colorado Red RAAC All Radio Equipped Vehicles RAFP AM/FM Cassette Radio RCDP 4 Speakers SBAP Power Steering SCGP Leather Wrapped Steering Wheel SUA Tilt Steering Column TMWP Tires TZAP Goodyear Brand Tires WJNP 15 Aluminum Wheels WLZC All Aluminum Wheels YEP Manuf Statement of Origin YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z65P Left Front Group XIV Z81P Front Spring Group X 2TCA Customer Preferred Package 2TC 25C Customer Preferred Package 25C 3VNA Customer Preferred Discount 4HA Special Scheduling Condition I 4M1P Retail to Bid Diversion Tracking 4UAA SCA Tissue North America LLC
  9. BUILD:6/10/87 BODY: JL62 *A6 Vinyl Trimmed Bucket Seats -Y1 DESCRIPTION NOT AVAILABLE AHY APA Monotone Paint BCQ Maintenance Free Battery CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating CKA Carpets - Floor and Cargo Area DGW 4-Spd. Automatic Transmission DMR 3.55 Rear Axle Ratio DSA Anti-Spin Differential Rear Axle ERB 4.0L I6 MPI Engine GPB Mirrors HAA Air Conditioning HCC Do Not Use - See HCA JHA Var Intermittent Windshield Wipers LMA Halogen Headlamps MBJ Black Front Bumper MDA Front License Plate Bracket NAA Federal Emissions NFA 23 Gallon Fuel Tank NHB Auxiliary Transmission Oil Cooler NHM Speed Control NMB Standard Duty Engine Cooling PE4 Colorado Red QE4 Colorado Red RAF AM/FM Cassette Radio SBA Power Steering TBB Full Size Spare Tire TBL Inside Mounted Spare Tire WJD 15X7.0 Styled Steel Wheels Z1B GVW/Payload Rating
  10. jdog
    I'm a Dad again!
    congrats, glad to hear everyone is doing good
  11. jdog
    1J7FJ26L1LL137503
    BUILD: 9/27/89 BODY:JL62 APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes CSRS Passenger Assist Handles DGSS 4-Speed Automatic AW4 Transmission DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMDS 3.55 Rear Axle Ratio DRJS Dana 35 Wide Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GNAS Rear View Day/Night Mirror GUAS Open JAZS DO NOT USE - See JP, KA classes JCAS 85 MPH Primary Speedometer KWXS DESCRIPTION NOT AVAILABLE K3ZS STRIPE/BADGE/MOLDING/COLOR LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS 35 Tire Body Color Fender Flares MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares NAAS Federal Emissions NBKS EVAP Control System NF5S 23 Gallon Fuel Tank QY3S SBAS Power Steering SCBS Steering Whl SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 167S Zone 67-Charlotte *X2 DESCRIPTION NOT AVAILABLE -YY DESCRIPTION NOT AVAILABLE ALA ALK Italia Package BAYP 105 Amp Alternator BCYP 95 Amp Battery CBAP Straight Back Bench Seat CKJP Black Vinyl Floor Covering DGB All 4-Speed Automatic Transmissions DHTP Shift-on-the-Fly,P/Time T/Case EAAC All Engines EAFC ALL Engines ERB 4.0L I6 MPI Engine GEC Front Left Side Sliding Window GFD Rear Sliding Window GRVP Left Manual Mirror HAA Air Conditioning JJAA Cigar Lighter MBJA Black Front Bumper MDA Front License Plate Bracket PY3 RAAC All Radio Equipped Vehicles RAB AM/FM Radio RCDP 4 Speakers TAAC All Tires TBB Full Size Spare Tire TNCA P195/65R15 BSW AS Touring Tires WLYC All Steel Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z66P Left Front Group XV Z85P Right Front Spring Group XIV 5KKA First American Title Insurance CO.
  12. jdog
    1JTMP65P8JT108113
    BUILD:12/23/87 BODY:JM62 *X4 DESCRIPTION NOT AVAILABLE -SA Charcoal ADL Skid Plate Group AGJ Driver Assistance Group APA Monotone Paint BCQ 750 Amp Maintenance Free Battery CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating CKA Carpets - Floor and Cargo Area DGW 4-Spd. Automatic Transmission ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GEC Front Left Side Sliding Window GFD Rear Sliding Window GSC Right Black Mirror HAA Air Conditioning JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K60 STRIPE/BADGE/MOLDING LMA Halogen Headlamps MBJ Black Bumper MDA Front License Plate Bracket NAA Federal Emissions NFA 20 Gallon Fuel Tank NHQ Transmission Heater PS4 QS4 RAF AM/FM Cassette Radio SBA Power Steering SCE Steering Wheel SUA Tilt Steering Column TBG Compact Spare Tire WJM 15X7.0 Chrome Wheels
  13. dewalt and milwakuee one for the house, the other for the job
  14. Hand Bill Murray or Robin Williams
  15. Yeah that's what I would think, might have to be a new project
  16. OH yeah and a ih travelall with a Cummins swap
  17. jdog
    CC cookbook
    So what's for dinner?
  18. Is that what that light means
  19. A beater A tesla 71 cuda 57-63 imperial " caddy 58-66 Lincoln 61 new Yorker wagon 61 fury 4speed Street comanche Unser racing comanche a long bed 2wd OH yeah and a few limos I like big cars lol
  20. seems strange seeing a factory spare in the factory location
  21. I know lol
