14
Alfa Romeo project progress
cruiser54 replied to cruiser54's topic in Member Projects: Other Cool Stuff
Got a piece of crud out of one of the idle circuits on Saturday. Idles great now. I've been bugged by the fact that it has such low gears. 4.56s with 14" tires. But, yesterday I took it out for a spin and at 110 MPH in 5th gear it was still pulling. I can live with that. -
Intake bolts...Any secret?
cruiser54 replied to coolwind57's topic in MJ Tech: Modification and Repairs
LOL. It's not a tough job. -
Need new battery cables? Mean Lemons is your guy.
cruiser54 replied to big66440's topic in MJ Tech: Modification and Repairs
Me too. www.meanlemons.com -
Removing the air cleaner is a big help. Ever use the "electrical tape in the socket" trick to hold the fastener while you use the tool to get things started? -
Fuel Rail Disconnect O-Rings Broken
cruiser54 replied to Jargon's topic in MJ Tech: Modification and Repairs
Fuel disconnects Quick disconnect part numbers The Napa part numbers for just o-rings *is: Napa 730-5018 3/8 Viton individual o-rings Napa 730-5017 5/16 Viton individual o-rings *Remember to re-use your old spacer between the 2 new o-rings!! Napa CRB 212305 fuel line repair kit 5/16 Dorman 800-750 trans line repair kit 3/8 Mopar repair kits: 83502745 fuel line repair kit 5/16 83504447 fuel line/Trans line repair kit 3/8 -
I've got 3 of them I can gather info from. It will be a bit later.
I'm feeling kinda left out......LOL How come not Renix?
new project, need help with renix
cruiser54 replied to hoenestly's topic in MJ Tech: Modification and Repairs
Begin by going to www.cruiser54.com and performing Tips 1 through 5. 27 ain't a bad idea either. -
Rusty's metal taillight housing
cruiser54 replied to riverrat92's topic in MJ Tech: Modification and Repairs
I wish I could do that stuff.. Very nice. -
I have a set I can measure if you want me to.
I decided to try Iridium spark plugs. I've had good success with them in my quads and my supercharged Miata. Only went on a 10 mile round trip, but I had to turn the idle down when I got home. Feels more responsive. The plugs I removed have less than 500 miles on them. NGKs also. -
It's a kick. Pulls from idle to 6800 RPM. 5 speed. 4 wheel disc brakes Coil rear suspension. 4.56 gears...Meh. -
JK Rubicon. Red. You have to mess with the bushings a bit. easy.
Renix/HO mashup questions (fuel pressure)
cruiser54 replied to JeepComanche89's topic in MJ Tech: Modification and Repairs
In my opinion, good used is better than cheapo knock off parts from china. -
Just use the 746s. You'll be fine. Have the stock fuel pressure regulator? -
Renix ECU, right? Start with something for stock Renix. Volvo 746s are a nice choice. -
This^^^. Cheap and excellent results.
I would look at the rear shoes first.
It's not pricey if you get the parts from Big David on Cherokee Forum. You know, with those shoes, if you don't have the drums turned and the shoes arced to the drums, you won't see much of an improvement. Ever removed the drums, cleaned off the shoes with brake cleaner and adjusted them properly?
Couldn't hurt I guess. I used that kind of stuff back in the day. If you have a Dana 35 rear, why not do the zJ rear disc swap?
This is interesting. Later XJ..... https://www.cherokeeforum.com/f67/98-booster-90-xj-242443/
- 70 replies
- Dual Diaphragm
- XJ
(and 7 more)
Tagged with:
Get a 52028186 factory stat and be done with it.
- 27 replies
Crack in A/C Control Unit causing vacuum leak?
cruiser54 replied to Jess's topic in MJ Tech: Modification and Repairs
How do you know the vacuum ball is holding vacuum? I relocate mine to the engine bay to eliminate the tubing getting corroded by battery acid.- 3 replies
- vacuum leak
- ac controls
(and 1 more)
Tagged with:
I'm gonna do a remake on the rear body at some point, so I decided to begin by removing the big, fat, ugly license lights. I have a new LED one ready to go on. It will be located below the plate and painted the same color so it blends in.
