cruiser54
    14
  1. Good question!! BYPASSING THE POWER/COMFORT SWITCH AUGUST 6, 2016 CRUISER54 25 COMMENTS EDIT Remove and unplug the switch. In the harness are 3 wires. One has a stripe, one is tan, and the other wire is black. Make a 4″ jumper wire with a male spade at each end. Plug one end of the jumper wire in the cavity for the tan wire and the other in the cavity for the striped wire of the harness and you’ll be in permanent Power mode. Stuff the harness back in and reinstall the switch for looks if you want. Make sure the 7.5 amp “Trans” fuse in the fusebox is good. If you happen to have a 91 or 92 XJ/MJ and it has the Power/Comfort switch, just jumper the Tan and Blue wires in the harness plug. NEVER include the black wire when jumpering!!! Also consider doing this: CRUISER'S MOSTLY RENIX TIPS RENIX GROUND REFRESHING OCTOBER 30, 2015 SALAD 27 COMMENTS EDIT The Renix era XJs and MJs were built with an under-engineered grounding system for the engine/transmission electronics. One problem in particular involves the multiple ground connection at the engine dipstick tube stud. A poor ground here can cause a multitude of driveabililty issues, wasted time, failed emission tests, and wasted money replacing components unnecessarily. All the components listed below ground at the dipstick tube stud: Distributor Sync Sensor, TCU main ground, TCU “Shift Point Logic”, Ignition Control Module, Fuel Injectors, ECU main ground (which other engine sensors ground through, including the Oxygen sensor, Knock Sensor, Cruise Control and Transmission Sync signal. All extremely important stuff. The factory was aware of the issues with this ground point and addressed it by suggesting the following: Remove the nut holding the wire terminals to the stud. Verify that the stud is indeed tightened securely into the block. If the whole stud turns, you can use a 7/32″ six point socket or wrench to hold it so the nut can be removed. Worst case, cut the wires and remove the stud and nut. Install new terminal eyelets on the wires when going back together. Scrape any and all paint from the stud’s mounting surface where the wires will attach. Surfaces must be clean, shiny and free of any oil, grease, or paint. Inspect the wire terminals. Check to see that none of the terminals are crimped over wire insulation instead of bare wire. Be sure the crimps are tight. It wouldn’t hurt to re-crimp them just as a matter of course. Sand and polish the wire terminals until clean and shiny on both sides. Apply a liberal coating of OxGard, which is available at Lowe’s and other stores. Reinstall all the wires to the stud and tighten the nut down securely. While you’re in that general area, locate the battery negative cable which is fastened to the engine block just forward of the dipstick stud. Remove the bolt, scrape the block to bare metal, clean and polish the cable terminal, apply OxGard, and reattach securely. Another area where the grounding system on Renix era Jeeps was lacking is the engine to chassis ground. There is a braided cable from the back of the cylinder head that also attaches to the driver’s side of the firewall. This cable is undersized for its intended use and subject to corrosion and poor connections at each end. Remove the cable end from the firewall using a 15mm wrench or socket. Scrape the paint off down to bare metal and clean the wire terminal. Apply OxGard. Reattach securely. Remove the other end of the cable from the rear of the head using a 3’4″ socket. Clean all the oil, paint and crud from the stud. Clean the wire terminal of the cable and reattach securely with a liberal coating of OxGard. 2 STRONG suggestions regarding the ground system: I prefer to add a #4 gauge cable from the firewall to a bolt on the rear of the intake manifold, either to a heat shield bolt or fuel rail bolt. A cable about 18″ long with a 3/8″ lug on each end works great and you can get one at any parts store already made up. NAPA has them as part number 781116. A further improvement to the grounding system can be made using a #4 cable, about 10″ long with 3/8″ terminals at each end. Attach one end of this cable to the negative battery bolt and the other end under the closest 10mm headed bolt on the radiator support just forward of the battery. NAPA part number 781115. For those of us with Comanches, it’s very important to remove the driver’s side tail lamp assembly to access the ground for the fuel pump. Remove the screw holding the black ground wire. Scrape the paint from the body and corrosion from the wire terminal. Add a 10 gauge wire, with an eyelet on each end, from that grounding point to a bolt on the frame. Better yet, on both Cherokees and Comanches, complete Tip 29 for the best fuel pump grounding. Be sure to scrape all mounting points to bare metal and apply OxGard also. If you want to upgrade your ground and battery cables with custom made parts, contact Neal at www.meanlemons.com Revised 02/04/2017
  2. Have you done any of the tips on my website? Adjust the throttle valve cable as Don suggested also.
  3. Did you use an intake gasket for the 89 or 96? Needs to be for the intake manifold you use.
  4. That's what the fuel pressure regulator regulates it to. The pump will make in excess of 100 PSI!!!!
  5. chances are you have a bad throttle position sensor also if the spring didn't fix it completely.
  6. Yup. Ah, it's a 90!! You can cut and solder or just solder over it. Hard to use shrink tubing that way though.
  7. The stock fuel pump makes plenty of pressure. It's the fuel pressure regulator that keeps the pressure correct.
  8. They haul buns and get great mileage.
  9. Just follow my instructions and you'll be fine. Don't need no stinking lists.
  10. Back in those days, you could order without having a package.
  11. http://cruiser54.com/?p=121
  12. Hydrophobic literally means “the fear of water”. Like an animal who has rabies. LOL. Hygroscopic is what brake fluid is. It's one of the most overlooked fluids when it comes to maintenance.
  13. Check the vacuum line from the throttle body to MAP sensor on the firewall. And do Tips 1 through 5 at www.cruiser54.com while you're at it.
  14. No. To keep everything else. Throttle body etc.
  15. You bet. Makes it easy.
  16. Here's things to consider when using an HO engine in a Renix vehicle. http://cruiser54.com/?p=100
  17. Was the starter covered in engine oil? I'll bet the starter is drawing way too much amperage under a load and causing the issue.
  18. New from the dealer. Used from a junkyard or someone who has some spares.
  19. Use an o-ring instead. See the link below to do it all properly. http://cruiser54.com/?p=68
  20. Or fuel related. Where did you get your injectors? Maybe they're leaking while shut off and parked with the engine hot.......
  21. Nah. EGR being deleted won't cause that.
