Ωhm
    6
Everything posted by Ωhm
  1. Loose starter motor.
  2. Download: Check out pages 86 and 87. May help.
  3. test
  4. Could be Fusible Link H:
  5. MJ uses a two (2) pin connector. Note jumper between terminals on the switch. This jumper continues the grounding leg for the Brake Warning Light to the IGN SW (bulb check) and the Parking Brake SW.
  6. Yes, if D2_4 showed voltage (B+ Hot at all times) with KEY OFF.
  7. Plus you'll get Brake Warning Light Bulb Check during CRANK and Brake Warning Light if Parking Brakes are ever applied.
  8. Twisted paired wires used for communication, cannot touch one another either. Check for wire to wire continuity. Sorry for the can of worms.
  9. Continuity testing will only find OPEN circuits. Each wire also needs testing for Shorts to Ground (STG) and Shorts to Voltage (STV). KEY OFF, select Ohms for STG. KEY ON, select Volts for STV. Doing these tests on the CCD bus, if its twisted paired wires will prove out the wiring, not the communications though. Also WIGGLE all wires when testing.
  10. With KEY OFF and everything connected, take voltage reading on D2_4. Should read 0vdc.
  11. Aren't those low numbered VIN'ed vehicles (#1) corporate archived or go to the very rich.
  12. 'tis the season
  13. Click on your username (upper right hand corner) and go to Account Setting, then go to Signature. Put your vehicle(s) Year, Engine and Transmission information there.
  14. This voltage is good. Check your glove box light/switch.
  15. Can't you just eliminate the Delay Module by disconnecting the connectors from the module and then connect them together. See LO works then.
  16. Ωhm
    1jthx6515gt029553
    Click on your username (upper right hand corner) and go to Account Setting, then go to Signature. Put your vehicle Year and Engine there.
  17. Maybe HVAC plenum design has something to do with heater core valve or no heater core valve.
  18. Ωhm
    wake up call
    Hope that ain't the happyoids making you talk like that. Stay well.
  19. Short read on reusing nuts. Check out the section: Re-use of Fasteners and Torque
  20. Sorry. I meant to the Left (CCW).
  21. Anyone. Doesn’t turning the Headlight Switch to the right, turn the interior lights ON (with dome light)?
