Ωhm
    6
Everything posted by Ωhm
  1. Maybe HVAC plenum design has something to do with heater core valve or no heater core valve.
  2. Ωhm
    wake up call
    Hope that ain't the happyoids making you talk like that. Stay well.
  3. Short read on reusing nuts. Check out the section: Re-use of Fasteners and Torque
  4. Sorry. I meant to the Left (CCW).
  5. Anyone. Doesn’t turning the Headlight Switch to the right, turn the interior lights ON (with dome light)?
  6. Pin_A is B+. Pin_B or Pin_C will ground the dome lamp. Remove wire from Pin_B to see if problem goes away. If not, reinstall wire and remove wire from Pin_C.
  7. Dome light is a three position switch. Center position is OFF.
  8. Back to normal. Problem unknown. Let hope it stays that way.
  9. Start vehicle, let it run, shut it off. Does fuel pump still stay on?
  10. With all 3 relays connected?
  11. Try one of the other relays in the fuel pump relay slot. Does pump still remain off?
  12. Should look like this. Should being the key word here.
  13. Without AC you'll only have 3 relays.
  14. Did the pump shut off with the relay removed?
  15. Pull the relays. Will that shut the pump off?
  16. Check your DOME fuse for the interior lights. As of the bus bar and TURN/BU fuse, it could be broke at that point.
  17. No B+ feed wire on TURN/BU fuse. B+ is supplied via bus bar. Bus bar feeds TURN/BU fuse, BLOWER fuse & RADIO fuse. Download the 88 wiring. Should be close enough for 86. https://comancheclub.com/topic/12083-electrical-manual/
  18. If you fix the TURN/BU fuse that should get you B+ to the Turn Flasher.
  19. Your right, that ain't right. Pull Turn Flasher, with KEY ON, does one of the two pins (fuse box side) have B+ on it?
  20. That looks real nice. Good job.
  21. Cubicles are like cages without bars. One good thing is that your computer is more important then you, therefore you get AC in the summer and heat in the winter. Stay away from the snack machine, resist.
  22. Solid looking bench. How about a back guard, to prevent pushing things off the back of the bench. Ask me how I learned this.
  23. Do Cruisers tip for CPS output voltage (AC). Make sure your meter is set to VAC. http://cruiser54.com/?p=50
