Ωhm
    6
Everything posted by Ωhm
  1. You also have a Closed Throttle Switch (CTS) located on the tip of the Idle Speed Control Motor (ISCM). Check this circuit for continuity and no continuity (open or closed circuit) by pushing the tip in and out. Connect ohmmeter between pins D2-7 and D2-13 for this test. KEY OFF.
  2. Do Eagle's tests. If this was your original setup (old cluster & oil pressure switch) then idiot light should have lit ON with KEY ON, Engine NOT running. Suspect open circuit between new oil pressure sender and gauge in new cluster.
  3. The grease in dialectical grease also helps when multiple terminals are mated together within a single connector.
  4. Check out page 75. Show vacuum routing. Should be the same as yours. http://www.eriejeeppeople.com/Jeep_tech/87_90_fuel_injection_renix/Jeep_Renix_Fuel_Injection_manual.pdf
  5. Isn't the canister vented to atmosphere through the charcoal?
  6. Try by using air pressure. BEWARE OF FLYING OBJECTS.
  7. Suspect starter motor. Welcome to the forum.
  8. Engine Speed Sensor = Crank Position Sensor (CPS).
  9. Ωhm
    Records
    What a great unit to own. How's your display? Mine needs bulbs.
  10. Ωhm
    Records
    Proud owner of the Sansui RA500 reverb unit.
  11. Ωhm
    Records
    AKAI. That when I stopped buying vinyl and started bootlegging all my friends Rock stuff.
  12. Ωhm
    Records
    My days of collecting 45's/Albums was the early, too mid 60's. Motown sound (Gordy, Soul, Motown & Tamla labels). Records have stood in storage so long now there probably flat on one side.
  13. Right hand side of engine compartment, mounted on a bracket, should have yellow caps on them.
  14. Closed Throttle Switch (CTS). Tells ECU throttle is closed. With KEY OFF, connect ohmmeter between D2-7 and D2-13. Push the plunger in and out. Does ohmmeter show switch is operating properly?
  15. Good news (lucky you) on having that original ECU. Good call, after proving everything else looked good (love your REM) and swapping ECU's. I'd still be on the lookout now for 89-90 ECU again.
  16. CPS fix was to bypass C101 and wire directly to the ECU. Can you back track the loose wires to C101 and determine there pin locations?
  17. Does your Crank Position Sensor (CPS) wires run directly to the ECU?
  18. Isolate the Radiator Temperature Switch. Disconnect switch. On the component side, run Fused B+ to a bulb, then to C243_B. Ground C243_A. Place bulb in a location where you can see it. Determine if Radiator Temperature Switch ever switches. Could determine which side of this issue is giving you your grief.
  19. You removed the fuel pump relay, hot wired pin 87, started engine, engine dies. Was the fuel pump still running after the engine died?
  20. Add possible lower radiator hose collapsing. Give it a squeeze.
  21. WELLS spec sheet: Normally Open Circuit; Closes at 198°F ±9°F.
  22. No Should be C243. Lower radiator.
  23. Do you mean C214_B?
  24. Don't know about TSB number. I.S. 32E is the Fuel Pump Noise number.
