Not to get into a pissing contest, but yes, you don't need the Headlight Relay Harness. LED's do cut back on current draw considerably. Now let's look at current flow without the relays. Battery, Fusible link, inside the Cab, Headlight Switch, Dimmer Switch, back to engine compartment, finally to the Headlights, then ground. About 20 feet worth of high current travel distance. So with the Headlight Relay, path is Battery, Fuse, Relays, Headlights, then ground. Not so many connectors and components and high current travel distance is now about 4 feet. Control of the Headlight Relays still needs to take the long way, but this low current stuff.
