Ωhm
    6
Everything posted by Ωhm
  1. Two things: 1) 50psi seems high for fuel rail pressure, could be the gauge used. Pull and check plugs for wet fouling. 2) Since you don't get fuel rail pressure when the fuel pump relay is installed. Disconnect and check for voltage at the Ignition Control module (ICM) connector C213_A with the KEY ON and during CRANK.
  2. Bad battery. 12vdc at battery doesn't mean it can work a starter. With DVOM connected across the battery, what does the voltage drop too, when IGN SW is in the CRANK position?
  3. So when you jumped the fuel pump at the fuel pump relay block you got fuel pressure, but still had a NO START condition?
  4. Did you jumper the fuel pump at the fuel pump relay block? Pin C216_1(30) to C216_4(87). Use a fused jumper.
  5. 1st post, 1st picture: We just got to love the grille.
  6. Looks good, low. Flip your grill, its upside down.
  7. Have your landline ring on your cell phone (call forwarding). Then you can screen calls using your cell phone.
  8. I need help. Looking for the mj88electricalmanual.pdf
  9. The ECU controls the Fuel Pump using the Fuel Pump Relay. At KEY ON the ECU will ground the fuel pump relay (coil) which will turn the fuel pump ON. If the ECU fails to see the CRANK signal within 2-3 seconds, the ECU will turn the fuel pump relay OFF thereby shutting the fuel pump OFF.
  10. Relays are located on the right side of the engine compartment. Can't find a photo. Need some help here.
  11. Pull the Fuel Pump Relay out. Does that shut off the fuel pump?
  12. Remove right (passenger) side marker lamp and try it on the left (driver) side.
  13. FP Relay is removed for these measurements. Looking for source voltage(s) to FP Relay.
  14. I'm looking for voltage at the Fuel Pump Relay Block without relay. No 2-3 seconds involved here.
  15. Check Fuel Pump Relay Block for voltage. Remove FP relay and check the following harness pins: C216_1 (30) Hot at all times. C216_5 (86) Hot with KEY ON or CRANKING.
  16. Possibility the Emission Maintenance Timer. Is the ORN/WT wire the IGN FEED?
  17. So the blower motor come ON, even with the Heater Mode Selector Switch is in the OFF position and your driving down the road?
  18. For me, yes.
  19. Isn't www.bteventures.com the host.
