Ωhm
    6
Everything posted by Ωhm
  1. AC ON or AC OFF, your idle speed should be the same. Your idle is high. My understanding is that 750 will be the target RPM's with engine at normal operating temperature.
  2. That throttle blade adjustment is a calibrated air leak. That setting puts the IAC in its best position for controlling airflow and idle. Do you think the first TPS could've been set to 17% or did you need the extra swing to set it to 17%? Either way, good news.
  3. Values you posted are all good and normal readings. I would now suspect the ECU itself. Let others chime in, maybe I'm missing something.
  4. Need to check powers and grounds to ECU. Your readings seem to be all over the place. Check for voltage (connect one lead at battery negative): D1-5: B+ at all times D2-4: B+ with KEY ON/START/ENGINE RUNNING D1-6: B+ for 2-3 seconds when KEY is turned ON or B+ at all times with ENGINE RUNNING Check for path to ground (connect one lead at battery negative) KEY OFF: D1-3: 0 ohms D2-8: 0 ohms
  5. Instrument Cluster (IC) has two (2) grounding points. C102 & C103. C102 pigtails out near the bottom of the steering column. C103 is under the hood on the middle left side of fender. If grounds are good, check C203 where it connects to the IC, could be loose.
  6. That's a great statement. Spending available voltage to force current through a connector/wire that's designed to pass current will generate heat. Thanks to all for your responses.
  7. Question is, does a unwanted (between M/F terminals) voltage drop generate excessive heat or not?
  8. Take a circuit with one (1) inline connector. That inline connector is designed to pass current unimpeded. If resistance increases between the contacts of the inline, voltage dropping will force current to flow. The resistance on the contact will start to act like "toaster wire". This inline was not designed to drop voltage. Ohm's Law, only apply to circuits, with components designed to handle the wattage. Keep in mind, this is how I justify to myself, how a voltage drop works on a connector designed to only pass current. So what I'm trying to say is "I don't know". Time for CC forum members to chime in.
  9. Pin A: Ground Pin B: B+ (from Headlight Switch (Lo beam)) Pin C: To Fog lamp relay (coil side)
  10. For your reading enjoyment. Modes of Operations start on pg76. Jeep FI Manual For real time data, checkout Renix Engine Moniitor (REM). R.E.M. I'll take it that the ECT sensor didn't help your HOT START issues.
  11. Generally speaking, O2S heater circuit goes OPEN. Good find on the IAT. Check ECT, also a known problem for hot starting issues.
  12. Check for ≈6 ohms across the O2 Heater Circuit. Measure between D2-9 and D1-3.
  13. Does your Heater/AC panel lamp work? Can you dim it? Do you have a factory Radio, if so, does your Radio Display Backlighting lamps work? Can you dim them? Do you have a Automatic Transmission, if so, does your PRNDL lamp work? Can you dim it?
  14. Ωhm
    Trip: MI to SC
    Noticed lots of utility vehicle convoys heading north or west. In VA now (I-77 & US58) for the night. JD, got out voted on which route to take. Majority said follow the vehicles on-board computer. So far, so good. Beautiful part of the country.
  15. Ωhm
    Trip: MI to SC
    Dorian put the hurt on a lot of good people down there. Your route makes sense.
  16. Ωhm
    Trip: MI to SC
    Yes, I stand corrected. Good eye.
  17. Ωhm
    Trip: MI to SC
    Google Maps kick us off I-75 at Findlay or Dayton OH to head South-East. Knoxville KY, as suggested, might be the way to go.
  18. Ωhm
    Trip: MI to SC
    Google Maps show me Interstate Highways with traffic lights and stop sign. Hence my question on I72, I73 & I74. Interstates seems to be connected by US roads. Hope they got good signage to follow.
  19. Ωhm
    Trip: MI to SC
    UPDATE: I just got off the phone with the DoubleTree Hotel and a couple of things. 1 – They have lost power, but were told to expect it to be back on by noon today 2 – Since they have no power, the phones do not work. When power is restored, they will be back on 3 – There is debris on the parking lot and property, but that is being cleared right now. 4 – They are de-sandbagging now 5 – They have to go room by room and take the beds off the risers they had put them on so that in case of water in the rooms, it would not damage them. They also change all the linens in every room and that process started at 9am this morning. 6 – The meeting rooms served as a storage space for all their equipment they had to place inside, so they are in the process of emptying them out and will be completed this weekend at the latest So……bottom line is, we are GOOD TO GO. Those who are arriving tomorrow morning may have to wait until tomorrow afternoon to be placed in their rooms, it depends if they have competed the room to room cleanup and after inspection of those rooms. I have told them to have 2 bartenders at noon and plenty of Miller Lite. They asked me to apologize to those who were coming in early for this “hiccup” and look forward to seeing all of us next week Appreciate your patience and again, I will keep everyone up to date if there are any updates or if anything changes. If you have any questions, please feel free to email me. On behalf of the 100th Promenade Nationale Corporation
  20. Ωhm
    Trip: MI to SC
    Leaving in the morning (Sat) from MI to Myrtle Beach SC for a veterans convention. I think Dorian missed or just missed. Any updates would be helpful? Also is I72, I73 & I74 mostly all the same interstate highway? Tough time reading SC roadmap.
  21. A/C Clutch Relay engages the A/C Compressor, this relay is controlled by the ECU with information from HVAC Controller. B+ from C236_A (connector for circle in picture) , thru A/C Low Pressure Switch, thru A/C Clutch Relay (87 (4)) to A/C compressor.
  22. Vintage soldering tools
  23. Wish we could have put a handle on your electrical problems better than what we did. Check C102 (Engine Harness to Front Lighting Harness). This connector is a known problem.
  24. No pics necessary if connectors look clean, no popped out wires touching other wires or strange growth on the terminals.
