KeppyMJ
KeppyMJ's Achievements
  1. Figured it out, I had to connect the factory fuel pump wire with the harness I made and it now runs great
  2. Didn't remove fuel pump relay just tapped into wire 87 for the fuel pump and not sure on if fuel pump is still running after it dies I will see. Thanks for the quick response!
  3. Fuel pump wiring was messed up by previous owner so I hot wired from 87 on the fuel pump relay and the pump works great but only starts for about 3 seconds. Did I skip over something and the ECM is freaking out? 1988 4.0
