Big Dan
Everything posted by Big Dan
  1. It looks like that part number is just for the wiring.
  2. I have a renix 2.5 flywheel, if anyone is needing it.
  3. I agree. The "YOU MUST REPLACE IT" non sense is over hyped.
  4. It doesn't apply, as much, to MJs as it is much easier to place the brackets correctly. However, the Super 35 upgrade easily handles up to 35 inch tires for those who can't locate a different axle. As all of the coil spring components can be a trick to place correctly, it is something that I am considering in my TJ.
  5. Found it now. GOODMARK GMK2111749681 Its from 70s dodge/Plymouth vehicles. I got mine, originally, off of rock auto. However, it looks like they're out of stock right now. Summit racing has them. https://www.summitracing.com/parts/gmk-2111-749-681
  6. Ill get the part number tonight. Its from a 70s dodge, I believe, and fits perfectly.
  7. With that being an XJ sender, it should work if you don't have the baffle in the tank. You just won't be able to utilize all of the fuel in your tank as the sender won't reach to the bottom. Sent from my Pixel 2 XL using Tapatalk
  8. Please do Sent from my Pixel 2 XL using Tapatalk
  9. Did you cobble one together from an XJ sender? Sent from my Pixel 2 XL using Tapatalk
  10. I don't know the part numbers off of my head, for pumps, so hopefully someone else can assist. As far as the sender, new ones are non existant for the 2.5L (junkyard trip will he needed). There has been a NOS 2.8L v6 sender floating around on ebay. 86-90 2.5L senders are compatible. 84-86 2.8L senders are compatible. What engine do you have? Sent from my Pixel 2 XL using Tapatalk
  11. A new one of what? The Bosch pump?
  12. Did the change over to the Chrysler logo keys occur in 1989/1990 or just as supply dictated?
  13. Was this ever verified if it worked on renix?
  14. You've got to provide more info. Whats going on? Super hot as in five minutes? Where is the temp gauge? What are your vehicle specs?
  15. It's easy enough for a two man lift. I removed and replaced my long bed, recently, by myself. It was difficult and would have been much easier with a second set of hands.
  16. I used the XJ hoses and cut them to length.
  17. I spoke without thinking. Hopefully a good solution is posted. Sent from my Pixel 2 XL using Tapatalk
  18. Honestly, i keep my pistol on me.
  19. No. The seat brackets are completely different. I don't have the image saved, but do a search on this forum. You'll have to transfer your MJ brackets to the XJ seats. Sent from my Pixel 2 XL using Tapatalk
  20. That's my bad. I didn't check. I thought it was NLA. Sent from my Pixel 2 XL using Tapatalk
  21. If, for whatever reason, that link doesn't direct correctly, search for "jeep Comanche drip rail". There's one passenger piece available for $40 shipped. Sent from my Pixel 2 XL using Tapatalk
  22. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F113143637598 Sent from my Pixel 2 XL using Tapatalk
  23. Starting in.. I don't know, 92 or 93, the AX15 used a .75 inch input shaft. The BA 10, as well as earlier AX15s, used a .59 inch shaft.
  24. Its the quick disconnect and the appropriate o-rings.
