Big Dan
Everything posted by Big Dan
  1. Also, what I did. Covered in loom and then ran it next to the master cylinder and along the fire wall[emoji106] Sent from my Pixel 4 XL using Tapatalk
  2. That's what I did Sent from my Pixel 4 XL using Tapatalk
  3. Change of heart? Sent from my Pixel 4 XL using Tapatalk
  4. Good deal! Sent from my Pixel 4 XL using Tapatalk
  5. Three "r"s http://www.tristarrradiator.com/ Sent from my Pixel 4 XL using Tapatalk
  6. Unless there has been a recent change, that is correct Sent from my Pixel 4 XL using Tapatalk
  7. It's finicky. It supposed to come from the factory with a spacer, that offsets it correctly, and it's ready to go. If that spacer if worn down some, that may be why you can move it and get brake lights. Potential fix is to line the spacer with something (tape/aluminum foil, similar) to get the offset correct again. There are no true factory adjustment procedures that I'm aware of. I ended up making a bracket and using a normal push style brake switch from a J10. Sent from my Pixel 4 XL using Tapatalk
  8. I would assume it would deteriorate the o rings. The o ring in your last picture is a regular injector o ring, if I remember correctly. The o rings inside of the regulator can be replaced. If someone else doesn't chime in with the part number, I'll look it up. Sent from my Pixel 4 XL using Tapatalk
  9. Without pictures, we really can't guide you well. However, please do a search. There are countless 4.0 vacuum line diagrams, on this forum, and those references will probably get you a quicker answer. Sent from my Pixel 4 XL using Tapatalk
  10. The part scribbled in red needs to come off. When doing the job in the future, torque needs to be applied where the green circle is, so the red scribble part stays in the pump. Sent from my Pixel 4 XL using Tapatalk
  11. If you do go the route of printing any kind of adapter, i would be interested. Sent from my Pixel 4 XL using Tapatalk
  12. Well.... Excrement Sent from my Pixel 4 XL using Tapatalk
  13. When you can, just a reminder Sent from my Pixel 4 XL using Tapatalk
  14. That would be a great find Sent from my Pixel 4 XL using Tapatalk
  15. What did you use to secure the new lights inside of the oem housing? Sent from my Pixel 4 XL using Tapatalk
  16. Please, please post more info Sent from my Pixel 4 XL using Tapatalk
  17. This won't directly answer your question at all. However, to be safe, just get a Mopar pump for a 2000 or 2001 XJ. They're still available and you know you're getting a correct fit part. If you don't want to do that, hopefully someone can provide additional info on the question. Sent from my Pixel 4 XL using Tapatalk
  18. What axle beam is that? I wasnt able to find anything by searching for, what looks like 4317833
  19. Well...yes, it's bad. But, there's been worse. It will be a good challenge.
  20. Yes Sent from my Pixel 4 XL using Tapatalk
  21. I bit the bullet and paid the $200 for a Mopar, pre filled, clutch master and slave assembly. It hasn't failed me yet and it's been on about 3 years. Sent from my Pixel 4 XL using Tapatalk
  22. There isn't one Sent from my Pixel 4 XL using Tapatalk
  23. I should have been more specific. When I said the pin out is different, I mean it's not plug and play. I assume most anything can work with enough splicing and doodiddling. Sent from my Pixel 2 XL using Tapatalk
  24. Someone will correct me if I'm wrong, but, the pin out won't be the same. So, no, that cluster won't work with your renix era dash wiring Sent from my Pixel 2 XL using Tapatalk
  25. Drain plugs. There are generic rubber sets, on Amazon, that you can get. It will be a multi pack and you'll have to see what fits. As far as a specific part number for the OEM plug, someone else will have to chime in. Sent from my Pixel 2 XL using Tapatalk
