Big Dan
Everything posted by Big Dan
fuel pressure regulator leak help!
Big Dan replied to RustyRodder's topic in MJ Tech: Modification and Repairs
Mopar ones are still available, as well -
IIRC, seats through 94, from an XJ, will be an easy swap of brackets. 1995 plus are more involved, but doable.
When you can, DM me your address. I'll box it up and get a shipping price.
Does anyone want/need a 2.5l renix flywheel? I don't need it and it's just taking up space. I'll send it to you for the price of shipping. If not, I'll just toss it out. Please take it. Shipping from KY.
I've still got one as well.
What else is out there besides General Spring and Hell Creek?
Clunking noise in rear right side
Big Dan replied to golddigger's topic in MJ Tech: Modification and Repairs
Same. The clunking that I have is the tail gate. Worth looking into, OP. -
clutch kit preference-quality
Big Dan replied to tarmac2dirt's topic in MJ Tech: Modification and Repairs
Thread revive here - I know the "throw away the Luk bearing" (or insert brand of composite bearing) is always said. I'll put one in for the camp of the provided bearing. I haven't had any issues with the Luk one. Currently going on 3 years. When I did my external slave swap, I actually bought a timken, and a national bearing, to compare to the provided one. National was gritty and off center. Luk and Timken looked fine. I ended up just trying the Luk. Point being - anecdotal, but, just check out what you have and make your decision from there. -
I'm behind in seeing this. Prayers for his family. This is terrible to hear.
I do
GOODMARK GMK2111749681 will work for j-bolts. Available on rockauto.
Bosch 69302 - Electric Fuel Pump
Big Dan replied to youngfred's topic in MJ Tech: Modification and Repairs
Anyone have any luck locating a source? -
I was not so lucky. I had a Bosch O2 sensor that lasted about 6 months. I was able to find a NOS Mopar sensor, ran that, and havent had issues. That's, obviously, only one case.
84-96 Sent from my Pixel 4 XL using Tapatalk
It's not made. I bought xj hoses and cut them to length. It will work. Sent from my Pixel 4 XL using Tapatalk
That's it. Glad it was found. He's a good guy, I've had no issues with transactions. Sent from my Pixel 4 XL using Tapatalk
Someone on here 3d prints them. I'll see if I can find the info. Sent from my Pixel 4 XL using Tapatalk
Hopefully this works better, for you, than it did for me. I replaced all of the o-rings and still had a small leak from there. Sent from my Pixel 4 XL using Tapatalk
Yes Sent from my Pixel 4 XL using Tapatalk
Broken connector by the O2 sensor on 89 4.0
Big Dan replied to oleskool's topic in MJ Tech: Modification and Repairs
Knock sensor Sent from my Pixel 4 XL using Tapatalk -
http://cruiser54.com/?p=280 Sent from my Pixel 4 XL using Tapatalk
Clutch issues - can't diagnose, video included
Big Dan replied to Big Dan's topic in MJ Tech: Modification and Repairs
Question for whoever reads this. This is in relation to my earlier comment about a feathery light clutch pedal. How stiff does your clutch pedal feel? Prior to the pressure plate, throw out bearing replacement, mine felt like any normal jeep. Now, while the clutch still engages at about half pedal travel, there is almost no resistance, in the pedal, it seems. It is the lightest clutch I've had experience with. EDIT - for reference, relatively new pre-bled Mopar Master/slave cylinder combo utilized. It was on for, perhaps, 100 miles prior to the clutch change. Clutch felt normal prior to work on transmission. I state that to, potentially, rule out air in the line. -
Same concept. With the caliper off, there isn't anything holding the pad there, outside of corrosion Sent from my Pixel 4 XL using Tapatalk
If your caliper is off, then I would assume that the pad is siezed to the knuckle, because its just sitting there, without the caliper. Give it a few smacks. Sent from my Pixel 4 XL using Tapatalk
Clutch hydraulics hooked back up...and everything works fine. That would, almost 100%, make the the missing transmission bolts (and subsequent partial tranny separation) the culprit. I had a bag full of 3/8-16 X 1 1/2" . As I read that was the appropriate size/length for the e12 bolts, I went ahead and put those in. Different threads mention 3/8” x 16 x 1 7/8” as the "other" upper bolts. I don't have any of those on hand, so I'll need to source at least one. However, I can't figure this out - Are the other 3/8" bolts supposed to have a nut like the 7/16" ones do? If the are supposed to have one, that would explain the missing driver's side 3/8 bolt. Please let me know either way. I also need to source a starter bolt. I am missing the lower one. I have read that it is, also, supposed to be 3/8-16 X 1 1/2". I'm not out at the shop now, but, Ill confirm that in a few days, when I return home. If that is NOT the appropriate bolt, if someone can let me know it would be greatly appreciated so I can go on and have it on hand. FINALLY - I don't know if it was the transmission partially separating OR the fact that the correct pressure plate is now present...but the clutch pedal is feather light. It still begins to engage/disengage at half travel, but there seems to be so much less resistance than before. It will take a little bit to get used to.
