Big Dan
Everything posted by Big Dan
If you've thought about moving your airbox...
Big Dan replied to Big Dan's topic in MJ Tech: Modification and Repairs
Yes, I put a fuse box and bus bar where the old air box was. Additionally, I just like the extra room to access things. And, the new intake doesn't take up much room, where it currently sits, so it not a hindrance in its new spot. Sent from my Pixel 2 XL using Tapatalk -
BA10/5 to AX15 advanced adapter kit
Big Dan replied to Bobby anderton's topic in MJ Tech: Modification and Repairs
As far as the second part of your question is concerned, I swapped in the older style AX15 (the .59" input shaft vs the later .75" input shaft). I was able to use my BA10/5 clutch and pressure plate, with the external slave, fork and throw out bearing. That may not be the case for the later style AX15s, so hopefully someone who has done that can chime in. -
Pics Sent from my Pixel 2 XL using Tapatalk -
I recently did this and it's freed up a lot of space, on the manifold side. If a similar set up has already been posted, my apologies. I used the following - 3" aluminum tubing Spectre Performance 8791 Black 3" Low Profile 90° Elbow Spectre Performance 99456 Throttle Body Adapter Spectre Performance 9712 Vacuum Sensor Adapter Kit 3.5" to 3" silicone coupler Air filter from a 1995 1.8L Acura Integra (I used WIX 46398) Pieced together an old renix harness to make a breather tube.. I need to make a more permanent solution. The throttle body adapter bolts up to the renix throttle body in order to give the TB a "lip"/nipple(?) for the tubing to connect to. The 90 degree elbow is then hooked to the throttle body, followed by the aluminum tube. I can get an exact measurement, if someone needs it, but, I think I cut my length at 18". The Integra air filter is used as it was a cone style air filter, but was an OEM paper style, instead of the K&N style, which seems to let in more contaminants than it should. The Integra filter base is a shade under 3.5". So I used a 3.5" to 3" coupler to attach it to the aluminum tube. Finally, I used a hole saw and the 10mm fitting from the 9712 vacuum sensor kit to make a breather.
Cruise Control Vacuum Line rounting?
Big Dan replied to C1111toro's topic in MJ Tech: Modification and Repairs
Glad you got it and glad that eaglescout was able to be much more descriptive than I was. Sent from my Pixel 2 XL using Tapatalk -
If memory serves correctly, it goes directly to the vacuum ball. Sent from my Pixel 2 XL using Tapatalk -
I've used these as well, they're great Sent from my Pixel 2 XL using Tapatalk
Exhaust Manifold Heater Hose Connector
Big Dan replied to WahooSteeler's topic in MJ Tech: Modification and Repairs
Sorry for the delay, yes it was 2.5" ID -
I hope to make it out to the shop tonight Sent from my Pixel 2 XL using Tapatalk -
I used this one. I had it on my 86 for about 2 years, before I sold it, without any issues. Sent from my Pixel 2 XL using Tapatalk -
No, one minute Sent from my Pixel 2 XL using Tapatalk -
I had no issues. I'll get the, exact, ID of the duct tomorrow. But, I'm pretty sure it was 2.5 inch. Sent from my Pixel 2 XL using Tapatalk -
I bought a hose from McMaster-Carr. I think it was 2.5in ID. One of their blue crush resistant duct hoses. -
They do, everything works now. Sent from my Pixel 2 XL using Tapatalk
Your pictures arent showing up. At least for me. Is anyone else having a similar issue?
No brake lights after power booster up grade
Big Dan replied to jeeptec1's topic in MJ Tech: Modification and Repairs
What size screws did you use? Sent from my Pixel 2 XL using Tapatalk -
It's the way to go. Sent from my Pixel 2 XL using Tapatalk -
Check to ensure the fuse is good. I thought I hadn't machined the rod correctly and went to a standard push type brake switch... Still didn't work. Turns out I blew the fuse whole messing around with everything. Sent from my Pixel 2 XL using Tapatalk -
You probably have a yoke for a th400. It's point 01 inches thicker. I had the same issue. Shop around, on ebay. I found mine for 55, I believe. Sent from my Pixel 2 XL using Tapatalk
They are different. For ax15 2wd, you need Spicer 2-3-10391x Sent from my Pixel 2 XL using Tapatalk
Since the ebay listing has, essentially, no information on what you get, I would contact them and find out EXACTLY what is included.
Internal to External slave AX5
Big Dan replied to WeezyBlue's topic in MJ Tech: Modification and Repairs
Hijack - do you know why AMC switched to internal? Sent from my Pixel 2 XL using Tapatalk -
This should help Sent from my Pixel 2 XL using Tapatalk
There's 6 or 8 (depending on year and if they've been lost) bolts and nuts to remove. I'll try to find the picture, showing the location of each. Sent from my Pixel 2 XL using Tapatalk
Are you pointing to the air hose? It goes from your airbox to the manifold to, I believe, assist with warming the engine up quicker. I picked some different sized flex hoses from McMaster-Carr and tested which one fit the best.
