Bobby anderton
Bobby anderton's Achievements
  1. Does anyone know the lengths and pitches of bolts for the AX15 bellhousing going into 4.0 wanting to upgrade to grade 8 and get rid of the e12 head.
  2. It is a 96 AX15 also does anyone know the lengths and pitches of the bellhousing bolts wanting to get rid of those stupid e12 bolts and upgrade grade 8 all the way around
  3. Changing BA10/5 to AX15 old tranfer case is amc 231. Found an AX15 with 231j transfer case. My question is can I bolt up the AX15 with 231j and it work. Going on a 1988 Jeep Comanche.
  4. It’s not an adapter per say it’s a kit with AX15 and bellhousing 23 spline output shaft for np231 transfer case that came with my ba so I can use the transfer case with my new AX15.
  5. Has anyone swapped Peugeot BA10/5 with AX15 using advanced adapters kits for np231 transfer case part #27-3510ax15. And if so how was it and does it include everything needed. Also I need new clutch and pressure plate so do I get AX15 ones or correct year model for Peugeot tranny.
