Tex06
Everything posted by Tex06
  1. I've got camo and gator seats that the PO reupholstered. Freaking awesome....I'll snag ya a pic tonight. Most upholstery shops should be able to cut you some foam and either double up on it or replace it.
  2. I just removed my smog equipment on my '92. From what I understand the charcoal canister connects the fuel tank to the air filter housing. I don't believe it would hold pressure anyways. Sent from my SM-G930T using Tapatalk
  3. Not even with a supercharged 4.0? :D Sent from my SM-G930T using Tapatalk
  4. If you can, backprobe the connector. I had a loose solder joint that threw the TPS and MAP voltage out of whack but only when both were connected. Individual connector probing and the 5V read fine, connect both and it dropped to ~3.2V. I got 12,13, and 24 together everytime. Sent from my SM-G930T using Tapatalk
  5. Lol. 75-80 all day with about 8in of rain. This weekend is gonna be a hot, muggy one. Thanks Cindy! (At least we didn't flood.... again) Sent from my SM-G930T using Tapatalk
  6. 4"lift up front, jks shackles in the rear. 31x10.5 r15 tires and American racing rims (unsure of backspacing, can measure later though). Pic of front control arm drop bracket and rear JKS shackle. What I have now that rubs is P255/75R17 Goodyear wranglers on stock 17" wrangler rims with the 1.25" spacer/adapter. And it definitely rubs.
  7. You need to find out what they're measuring. There's not enough info for a good troubleshooting session yet. Do they give you a printout in your state? Sent from my SM-G930T using Tapatalk
  8. I would think lacquer thinner would work. Has the system been open to the environment? Sent from my SM-G930T using Tapatalk
  9. Well, found out why the A/C was likely disconnected. Hole in the evap casing.... Which means I'll be pulling my carpet son because I bet this thing dumped water all over the floorboards. A little fiberglass, a little paint and it should be good to go. Sent from my SM-G930T using Tapatalk
  10. Would greatly appreciate the resistance vs temp chart if you can find it! Sent from my SM-G930T using Tapatalk
  11. Lot of questions here. I can tell you you'll need more than 4" to clear 32" tires, I'm running stock rims from a 2012 or 2013 Wrangler with roughly 32" diameter tires (whatever came on them and 1.25" spacers) and I scrub in sharp turns. Had 31" before with no issues though. 1992 Pioneer, 4" lift although it may have a little sag to it at this point (ride is good though, used drop brackets for the control arms). Can get you the tire and wheel specs if you like from before, they're in my shed. I also had questions about cooling, my gauge reads 210 normally and climbs as well. I've never heard the aux fan kick on either, although I did test it once to make sure the fan itself was operable (it is). Does anyone know how to test and see if the computer is switching it on at the right time? I've seen temps in the 230+ range while sitting in traffic....I'm halfway through installing A/C and I don't really want to compound an overheating problem in the summertime.
  12. Other questions: I'm assuming the PAG oil capacity is the same as the original mineral oil. Can anyone confirm? This is what I found do far: COMANCHE 1990-1992 All Engines R12 38.00 Mineral 4.50oz 1989 All Engines R12 32.00 Mineral 6.00oz Also, I managed to break the t'stat. MOPAR number is 55035503... anyone seen a replacement of these? I did a quick search and came up empty so far. Sent from my SM-G930T using Tapatalk
  13. Here's the parts needed for the A/C. It looks like the hoses I have are for the 4 cylinder MJ. I'll have to figure out if it'll fit or not. Sent from my SM-G930T using Tapatalk
  14. Which motor? Sent from my SM-G930T using Tapatalk
  15. I'll do my best. Tomorrow I'm pulling the dash and installing the heater core and evap coil. Sent from my SM-G930T using Tapatalk
  16. Father is an A/C man and all the specs are available online. Have gauges, 2 vacuum pumps, etc. Even if ya do over or under charge the system, they're pretty forgiving. Sent from my SM-G930T using Tapatalk
  17. Pressure washer or hose with a nozzle? Just fish it up there and let it run for a bit. Sent from my SM-G930T using Tapatalk
  18. I'd call it 5.25". Judge for yourself. Sent from my SM-G930T using Tapatalk
  19. Still need a measurement? Sent from my SM-G930T using Tapatalk
  20. Hope those help. Bottle for scale, don't have a tape with me right now. Sent from my SM-G930T using Tapatalk
  21. Gimme 5 minutes Sent from my SM-G930T using Tapatalk
  22. Thanks, I'll look into this tonight! (And compare what I've already got) Sent from my SM-G930T using Tapatalk
  23. Wouldn't happen to have pics by chance would ya? I don't want to get halfway into this and have to wait for parts..... According to RockAuto: ******78 is Suction Line (Low Pressure - Compressor to Evaporator) and ******79 is Discharge Line (High Pressure - Compressor to Condenser) Sorry for the weird text, copied and pasted from their site. They're not showing other hoses....I'm wondering if the ones you mentioned are hard pipe that is bent into place?
  24. You don't happen to still have said javelin do ya? I've got a particular soft spot for those.... Sent from my SM-G930T using Tapatalk
