Everything posted by Tex06
Wooo! Finally got a good no- start!
Tex06 replied to Tex06's topic in MJ Tech: Modification and Repairs
Got a quick chance to test voltage....only seeing 4.81V at the connector. Not good....I'm gonna back probe this afternoon, if this is like my TPS issue then there's corrosion somewhere I need to find. Question: Is this 5 VDC the same as the 5VDC at the TPS? I'd like to check it in reference to the TPS ground (a known good signal ground) and see if I can eliminate the ground or the +5V side from my troubleshooting. -
Too bad you're not a little closer. I'm looking to get rid of my '08 Mazdaspeed 3. Is hatchcar, Zoom-zoom! Sent from my SM-G930T using Tapatalk Is that Mazdaspeed 3 a turbo engine? Or was that a couple of years later? Heard those turbo engines were really hot and easy to goose up for even more Zoom-Zoom!Oh yeah. Turbocharged 2.3 L good for about 275/275 from the factory. Easy to hit 300hp with just a tune, start throwing parts on it and you can be in the 550+ hp range real quick. I've embarrassed many a new 5.0 'stang with my little hatch... Sent from my SM-G930T using Tapatalk
Yep next step is to back probe. Gonna have to wait until tomorrow, left the meter at work. For now I'm gonna run it with the MAP unplugged. Sent from my SM-G930T using Tapatalk -
Worked on Rambo last weekend, installed the headlight relay harness, replaced the valve cover gasket, vacuumed out the inside. Started up afterwards and got a CEL. Checked it today and got 12-14-13-55. 12 & 55 were expected. 13 &14 deal with the MAP sensor. Tried to start and it turns over and coughs but doesn't quite catch, even when holding the gas pedal (sorry, I'm still a carb guy with carb habits). Disconnected the MAP, hard to start but will, just doesn't like to idle (duh no MAP signal). Grabbed a spare MAP and swapped it in (high quality GM junkyard unit). Exact same issues. No start with, hard start disconnected. Already reset the codes by disconnecting battery and touching + to -. Tried it all again. No difference. Any ideas? I'm currently looking over my connections again... Sent from my SM-G930T using Tapatalk
Only way I can easily upload pics from my phone, otherwise I wouldn't use it. Sent from my SM-G930T using Tapatalk
Is this your way of saying you'd rather I'd not be on the forum at all Don? You know maybe I should have put $50 on Clemson :banana: Man some people are sore losers....... :peek:
I don't think that was the right link Don. Pulled up a nasty dispute between a member and some mods on deleting his post. I'm gonna try searching again... Sent from my SM-G930T using Tapatalk Huh, link works fine on the computer. Checked it again on my phone and it pulls up the same spat between a certain member and several Mods. Odd......
Renix Engine Monitor scan tool
Tex06 replied to 87MJTIM's topic in MJ Tech: Modification and Repairs
This is identical to mine: Sent from my SM-G930T using Tapatalk -
What exactly is that? Sent from my SM-G930T using Tapatalk
Drop hitch and bunker questions
Tex06 replied to Jackrabbit41's topic in MJ Tech: Modification and Repairs
Harbor freight and Northern tool have cheap 6" drop hitches. Should be good to go with that. Sent from my SM-G930T using Tapatalk Also, how did you wipe your license plate in that first pic? Kinda cool Sent from my SM-G930T using Tapatalk -
Ummm.....maybe! Let me see if I can figure it out. Sent from my SM-G930T using Tapatalk
Side note, I've got a set of 12 bolts that will work for the door. 8mmx1.25x30mm Local pickup free in Baton Rouge Area or I can bring them to ATL next month. Sent from my SM-G930T using Tapatalk
Turns out that the JIS bolts were the better of the two. (I liked the smaller hex and slightly larger flange, although both fit fine). One for bolt swapped (lower hinge): All the upper bolts swapped: Bolt comparison: Tool used (size 40 torx) : Hope this helps! Also, don't force getting the old bolts out....I nearly stripped 2 in the passenger's door so now I'll have to pull the fender and use my impact to drive them out with the door off the truck. Sent from my SM-G930T using Tapatalk
Shift tower........help,... please help...
Tex06 replied to madog7200's topic in MJ Tech: Modification and Repairs
No idea. I can measure my spare AX-15 shifter if ya like. Sent from my SM-G930T using Tapatalk -
Any luck? Sent from my SM-G930T using Tapatalk -
Yep Sent from my SM-G930T using Tapatalk -
No set screw in the AX-15 shifter. Put lower piece in a vise and use a big punch (brass is best) and a hammer. They will come apart....I just did mine to replace the rubber seal atop the shift tower that keeps air/ water out of the cab. Sent from my SM-G930T using Tapatalk -
Glad you got it! Sent from my SM-G930T using Tapatalk
Junkyard not an option? Sent from my SM-G930T using Tapatalk
Other than that....wiggle wiggle wiggle wiggle wiggle, yeah. :D Sent from my SM-G930T using Tapatalk
Ewww. Not as sure then. I just rebuilt mine and reinstalled with an external slave (swapped from internal). I had a little lube on the splines of the input shaft and make sure your shift tower isn't hitting. I took mine off then reinstalled after the crossmember was installed. Sent from my SM-G930T using Tapatalk
Swap or previously had an AX-15? Sent from my SM-G930T using Tapatalk
