Tex06
Everything posted by Tex06
  1. Yeah I'm not comfortable running it long enough to do that. That would be my normal routine is bust out the propane and look for vacuum leaks but it's revving waaaayyy too high for my liking. Pulling it all apart today and gonna reseat the intake (without header wrap this time......sigh).
  2. Header bolted to engine (otherwise intake would fall off). Nothing bolted to header. Exhaust dumped roughly at the firewall under the gas pedal. 4 months. Yes it's loud. Yes you have to drive with the windows open or you'll probably suffocate. No, it won't hurt the engine for a short while. Or a longer than short while.
  3. That's what I was afraid of. TB looks fine, reused my old one. Had troubles getting the intake to seat properly due to header wrap.... I'm willing to bet that's the issue. Dammit. Sent from my SM-G930T using Tapatalk
  4. Oh, and I drove like I was qualifying. Full throttle everywhere, 4k shifts. After it stood up to that my jeep was a keeper. Sent from my SM-G930T using Tapatalk
  5. I did it for about 4 months. Great fun, really loud. My header wasn't connected. Only downside.... you suck up a lot of carbon monoxide while driving. Sent from my SM-G930T using Tapatalk
  6. Ok, first off I'm actually scared to start my truck. Just did the manifold swap. 99+ intake, new exhaust. New power steering pump, all that jazz. Go to start and.... the engine takes off like a jet. Immediately revs to 4k before I shut it off. Did this 2 or 3 times. Disconnected the MAP and still does the same thing, although harder to start. Any guesses? Kinda need to get to work in the AM. Sent from my SM-G930T using Tapatalk
  7. Just how capable are the BFG A/Ts in mud and dirt? I run them on my '86 K30. They do alright in sand, pretty good in mud, etc. I don't do a lot of off-road but I do see a lot of dirt roads and mud. I like em. Sent from my SM-G930T using Tapatalk
  8. Shouldn't. It's a bear of a job though... set aside a whole weekend. Sent from my SM-G930T using Tapatalk
  9. Google "how to retrieve codes OBD1 jeep" for the 91-92 models. The truck will tell you from a very limited code selection. The renix motors, I'm less sure on. Other than that, do you have a specific issue? These aren't new cars that self diagnose, lol. Sent from my SM-G930T using Tapatalk
  10. Ooh... pretty toys. Very nice. Sent from my SM-G930T using Tapatalk
  11. Oh and a wobble extension. Very important tool to own. Mine older ones are snap on, newer ones are harbor freight. Sent from my SM-G930T using Tapatalk
  12. Long extension x2 and a dab of grease or a piece of tape. Usually takes about 7 minutes. Sent from my SM-G930T using Tapatalk
  13. Radio diagram 92 mj only Sent from my SM-G930T using Tapatalk
  14. Fuse application, 92 mj/xj Sent from my SM-G930T using Tapatalk
  15. Dunno about offroading but I keep a TPS, MAP, and CPS near at all times. Just in case :)
  16. Like dis? Sent from my SM-G930T using Tapatalk
  17. You have any pics here of the other projects? I worked on a Dodge Polara with that damn pushbutton auto transmission.....what the hell were they thinking (or were they)?
  18. Yep. BWD might get ya home in a pinch....then again it might not, lol. I've found that NAPA electronics aren't too terrible, but a lot of my spares come from the local pull-a-part. They usually charge $3-10 per whatever and I'll either bench test it or just swap it in and see if it works. If not, take it right back and they'll credit ya (which I can use on another one!).
  19. Sounds like you need to start scrounging the junkyards for a same or similar year XJ. Pull as much as you can from it, HVAC box (if it's cracked you can fiberglass it. I just did mine), A/C controls, wiring harness, compressor bracket, and all the pictures you can take before and while you pull this stuff off. I've got an '89 XJ 2-door that I'm trying to get rid of, problem is it's in another state (Georgia). I'll try and find any pics I may have of it.
  20. Well that was a very cool read. Didn't know Bendix had done an electronic fuel injection system that far back. The Corvette Rochester systems were totally mechanical and a real PITA to work on. Thanks Cruiser!
  21. The folks at jeepair.com are pretty helpful with kits and such. Sent from my SM-G930T using Tapatalk
  22. I've got wiring diagrams if ya need em for the '92 Sent from my SM-G930T using Tapatalk
  23. I may have one that I bought that would work. P/N: 56278 made by four seasons. If ya want to give it a shot I can take measurements for ya. Bought it and won't need it (still in the wrapper).
  24. I've got the BFGs on my Chevy K30 and have 0 complaints about them.
  25. Apparently the '92 uses a Low Pressure Switch and and '96 uses a High Pressure switch........ Shouldn't matter, switch is closed when pressure is within spec, open when it's not. The '96 is 4x the price though....sigh.
