carnuck
Everything posted by carnuck
  1. It has a Chrysler Jeep emblem (2 years after the hostile takeover)
  2. So you're saying my 86' with a three speed auto 904 has a 23 spine output? That's right. Same output as the 727 in FSJs. Probably a NP229 tcase too!
  3. 1/2 way up my 4.2 mile long driveway. Actually, headed back out after being denied on the icy switchback. I don't feel bad though. It was only 2wd and there were 3 4x4s skidded off the road and almost into the river at the top. I didn't see them until I was almost over the top and started sliding sideways. I let the truck roll part way back down, ebraked to spin around towards the hill then stopped for the pic. My snow "chains" are 2 comealongs I took apart and wrapped through the wheels as 33/9.50/15 chains weren't available.
  4. Try a jumper lead from the main terminal of the alt to the battery + and see if everything turns on.
  5. Compare your firewall and especially the floor on the driver's side with an '87 up XJ.
  6. check out http://planethoustonamx.com
  7. I think someone on NAXJA was selling replacement header panels for round headlights
  8. No off position? These were set up to allow a little air flow whenever moving. If it's cold, turn the heat on.
  9. I have a Jeep shop jacket with my name on it (parting gifft from when I worked at the Ford dealer but only drove Jeeps to and from work. They also owned the Jeep dealership where I wanted to work)
  10. Sticky wheel cyls, sticky load level valve, rear brakes out of adjust. If that's clean then the booster.
  11. I run the tricolor H4 lights and wear blue blocker sunglasses in the fog or snow. It's like 3D vision!
  12. Sorry. Been crazy the past few weeks. (in more ways than 1. I may be looking at the big D)
  13. The trans length is different between 2 and 4x4 trans. I would just get a 23 spline trans and case together to put in.
  14. Look at the physical size of the pumps to tell them apart.
  15. KJ wheels won't fit. They hit the tierods (found out the ahrd way. Too much offset!)
  16. Trans with matching tcase (check the spline count! '91 up are 23 spline. Before that 21 spline except 3 speed autos) Trans crossbar and mount. Tcase linkage (I converted from 2wd), engine wiring harness with the shift computer (under dash passenger's side) and PCM
  17. Ignition module under the coil?
  18. Ditto on NAPA. I would take the pressure control valve from the older style pump and put it in the new one to up the pressure. The steering boxes are NOT all the same. There are different ratios (just like diffs)
  19. AKA: tan AMC's official name for it is beige. There was a long running thread from about 10 years ago on the AMC list about it.
  20. If tehre was play in the throttle plate screws and bushings, the suction could pull it enough to catch on an edge that it wouldn't without vacuum. Missed the other stuff :ack: I'd try another throttlebody since nothing else seems to be causing it. 20 inches of vacuum is higher than most motors when not coasting though.
  21. They wanted $10 a month here in WA for the router. I bought a router, but it's not working fast with SUSE Linux 11.3, but it's smoking fast with XP. No idea why? (A LOT of SUSE guys are running into that)
