Everything posted by rokinn
Door hinge backing plate - door side torx
rokinn replied to pizzatree's topic in MJ Tech: Modification and Repairs
Forgot about those tabs. I at have at least one, maybe two, in the event yours isn't salvageable. -
That's just a 3/16" thick plate that is independent from the door itself. It's likely rusted to the door metal. A good wacking on the bolts should dislodge it. May have to soak it some with blaster before it comes loose. -
Would you recommend getting this trailer hitch?
rokinn replied to robfg67's topic in MJ Tech: Modification and Repairs
I'm interested in the tail gate cap. Not sure how to see or acquire that particular one if it's good. Is there a link or a way to inquire about that one. thx -
Sealing Glass on Wing Window
rokinn replied to Drahcir495's topic in MJ Tech: Modification and Repairs
IIRC the glass is already a pretty snug fit without any thing else. Getting a well cleaned and precise fit on the rubber parts will be the key in having wing windows that don't leak. The only time mine will have some small leakage is if I spray directly at them with the high pressure wand at the car wash. -
Wrecked 92 Comanche - Yuma AZ
rokinn replied to damianriel's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Never mind the truck. Someone is very seriously hurt if not dead from a T-bone like that. -
https://www.alcanspring.com/ I got a quote from these guys in Grand Junction, CO. It was a fast response and you can order custom specifications right on the website. I wouldn't say they are particularly cheap but they make them exactly the way you want. I didn't end up going that route however.
If someone actually wants to learn something about the Comanches read "Empire of the Summer Moon" by S.C. Gwynne. It was a finalist for the Pulitzer Prize. Fascinating read! It should also be noted that the Comanche nation has its own constitution. BTW, America is actually a continent, two in fact, north and south. It could be construed that everyone living on them are American. Not just citizens of the United States (of America).
The line just breaks completely in two.
I recommend looking between the ball behind the front bumper and where it comes through the body up toward the battery. Common place for it to break.
Head gasket replaced, now no start..
rokinn replied to Jeep88Comanche's topic in MJ Tech: Modification and Repairs
Check Cruiser's Tips #12 -
Is my hood dented.... or is my front clip drooping?
rokinn replied to VorTekX's topic in MJ Tech: Modification and Repairs
I believe the hood latches are adjustable. -
Ford - Found on road dead.
X2 on the Firestone Destination AT.
Renix 4.0 overheats when driving
rokinn replied to jamespwsullivan's topic in MJ Tech: Modification and Repairs
I put a 91+ thermostat housing on mine. Before I installed the electric fan I just had a plug in the hole. Have a thermostat with a hole in it and the 91 housing with the plug removed when filling. When coolant starts coming out the housing hole put it back in and you're pretty much have the system bled. I now have a switch in that to turn on the efan I installed. I never overheat now whereas I had a lot of problems overheating before, especially when idling for long periods, going too slow or towing up a steep hill. If I need to fill the system now I just remove the switch. It's a great addition. -
Been there with the eyes swollen shut and itchy privates. Cortisone shot was the only answer. Another time sitting for two weeks in over stuffed chair with arms weeping onto towels. Now at the first sign I rub cortisone cream on affected areas and it seems to nip it in the bud. Never use hot water to wash. It will spread it very quickly. The lemon approach sounds like it could be effective as well. Hope I never have to find out. Another thing to try is covering the area with clear plastic sheeting for a couple of months. Bake it to death. I would also use eye protection and an effective respirator when removing it. I've heard of people dying from inhaled poison oak smoke so definitely not an answer.
If you are leaking coolant eventually you will overheat. You may have a pin hole leak in the radiator or some other place. When you shut off the engine and there is a leak somewhere you will suck air from that site and then your cooling system is compromised. You may also have a bad fan switch.
Do you happen to know the diameter of that bar? I picked up a ZJ V8 one from the JY some time ago but I think it's only 26mm if IIRC. Perhaps it didn't have the proper V8 in it.
No it's not. Maybe they would be open to shipping. I live about 40 minutes from them.
These what you're looking for? https://boulder.craigslist.org/pts/d/firestone-jeep-cherokee-xj-or-comanche/7599751127.html
Notwithstanding the occasional denigrating characterization of individuals with a lower level threshold for managing their anxiety and perceived threat (real or not) doesn't mean their assessments are without merit. Riding in a vehicle that doesn't have head rests is a pay your money and take your chances kind of situation. Having been rear ended when I was in my 20's transformed my life for the worse for nearly a couple of decades experiencing severe neck pain, debilitating headaches, and post traumatic vision syndrome. The better my vision was corrected the worse the headaches became. I was barely employable for much of that time. Cervical spine arthritis and spinal stenosis being the current state of affairs in spite of the therapy I did to heal the injuries. I had headrests but the car was crushed up to the back window and the seats broke loose from the floor boards. I was making a left turn on a semi rural road at sunset and the car behind me didn't see me or slow down. In the late 90's someone ran a stop light in a snow storm T-boning me on the drivers side at the front wheel resulting in a brain injury that took a good 5 years to even begin to see the light at the end of the tunnel. Personality changes, depression, cognitive and memory losses and years of testing and therapy was the result of someone else's negligence. In many instances the drugs that were prescribed only worsened the symptoms. Business and income losses diving into debt that wasn't quickly or easily resolved. Luckily I have made a full recovery, in some ways I'm healthier than I was thanks to state of the art trauma therapy. Something I decided to get trained and certified in myself to add to my 30 year profession in structure integrative bodywork. The human kind! I'm not paranoid but I also drive very defensively. Took me awhile to get to that point having once been diagnosed with PTSD. I don't assume that others are following the rules of the road or even paying attention, what with the new danger, cell phones. Not tail gating is your best defense from being rear ended. You might have the reflexes to stop in time but that doesn't mean the guy behind you does. There are a great many reasons why people have different self regulation capabilities around anxiety (free form or not) and fight or flight responses to stimuli. Critical and denigrating attitudes toward them only reinforces the complex, jeopardizes the bond you may have with them resulting in a loss of trust and respect. Resourcing their notions of success and a positive experience and outcome in any situation, MJ's or not, is paramount to expanding a persons ability to confront challenging situations unique to them.
90+ degrees of play means something is seriously wrong and you shouldn't be driving it if you value living. I'd be looking at steering gear as first on the list given your description but could be other components as well. If you have to take it to a shop have it towed there. Otherwise start looking for what might be broken. I was inches from going in the river when the tie rod on my grandfather's old jeep pickup broke. A little too close for comfort as they say.
35 ft lbs. Go tighter from there to get the cotter pin in.
Make sure the castle nut is tightened to proper torque.
