Everything posted by MancheKid86
looking for a comanche, has to have a 4.0L doesnt have to be 4wd, i can convert it to 4wd in a day lets see what you got. my truck jumped first, and ran me over, drug me 20 ft down my driveway before i was free, and it then rolled atleast 12 feet down an embankment to the road below writing it off call/text me at 250-864-8372 for an almost instantaneous response, or post here and ill check back daily
Need a detailed, plus bare minimum removal guide Doing my heater core replacement tomorrow or the nextday Any tips would be appreciated
Does Vin Tell Gear Ratio? Or Any Other Clues
MancheKid86 replied to DaveB26's topic in MJ Tech: Modification and Repairs
there is a data tag bolted onto your axle diff cover, it will tell you your gear ratio -
My Badass Metric-Ton Comanche Build! (The End)
MancheKid86 replied to MancheKid86's topic in Member Projects: Your Comanches
Empty Post -
Empty Post -
Empty Post -
Major Oil Leak, Burning On The Crosspipe. Help!!!
MancheKid86 replied to Dedaw's topic in MJ Tech: Modification and Repairs
check the bolts on the valve cover and oil pain? could have rattled loose since your torqued them uppon gasket installs? -
clutch pedal snapped in half while doing 100 mph, yes 100 mph, And yes the pedal, i learnt really quick how to shifT matching engine to ground rpm, had to drive 100 km like that XD
id buy it for $100,<br />and then new fenders and doors,<br />remove the bed and truggy the rear,<br />sand er all down + paint<br /><br /><br />but thats just me
*edit* Didnt read page two xD
WRZ's comanche Now the 96 od2 swap in progress
MancheKid86 replied to Wrz's topic in Member Projects: Your Comanches
nice progress so far, doing very detailed work just a question tho, while the engine was out, it got new/cleaned accessories, sensors, seals, how come you didnt rebuild the inside? other than that keep up the good work -
i have a passenger side forsale, ready to be re welded in and painted :) my drivers side was rotted to nothing, so i deleted both both sides and upgraded to the newer style seat c channels/brackets/seats
oyaji, he is not overloading his engine to the point to over heat due to any spark issues, tire size, gear size, he states that INCREASED RPM will induce the over heating, INCREASED RPM IS A PARTIAL RESULT OF DROPPING GEARS! SO OBVIOUSLY HE WILL OVER HEAT FASTER if he drops gears every where like you suggest, as well as you state that driving in second will save him money, NO, you are driving slower with way more rpms, more rpm's = more fuel being burnt = more gas consumed heck, if that were the case my truck would over heat every day, 3.55 gears with 35" tires, but it doesnt, it runs actually around 150, so do us (or me atleast) a favor and stop posting on this topic, you are disregarding every input, and making it seem like they have no idea what they just typed, save every one the grief i apologies to every other participant in this thread for my outbreak, but this dude drove me nuts just reading this, I'm sure your all going nuts too paradiseMJ have you tested your tsat? just toss it in a pot of water and boil it until it opens, make sure to have a thermometer handy to see the temp it opens like jimoshel asked, have you pulled your frost plugs out? and don't know if this applies, ive read about the 3 row radiators having lots of overheating issues where the owner swapped back to a oem single row with no issues afterwards, could this maybe be the same with your 2 row? thats all i got, good luck
Radio Has Me Goin Insane
MancheKid86 replied to redwolf624's topic in MJ Tech: Modification and Repairs
take a pic of your connector from the antenna -
there was a thread on someone having an antenna with a two way connector, they swapped it back to oem and it worked just fine -
Chrome Tail Lights Ebay
MancheKid86 replied to dancome433's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
well than, I'm sitting on a gold mine! -
Alexia's 1987 To 1997 Comanche
MancheKid86 replied to Alexia's topic in MJ Hardcore Tech: Epic Journeys to Greatness
The rage extreme is bondo, and the glaze isnt just for pinholes, You sand the "body filler" with 80 grit that is way to coarse for high bild primer/sealer/paint The putty glaze blends and fills the scratches, and is able to fi.ish in a much finer grit, reducing the ammount of times it needs to be high builded and sanded, and is also allows the bondo to flex with the metal more, Just a tip dude, I like your progress so far But seriously keep it up -
Need A Photo Of A *painted* 87-92 "comanche" Emblem
MancheKid86 replied to Pete M's topic in The Pub
*edit* thought i had somethin but nothin -
Bigger loop yes, if your gettin snapped out you gonna trust a 1 1/2 ring? Also on the winch topic, there s rope for winches, also most winches now a days have an in cab controller, the onlt way it will snap is if its not maintained and tensile strength rating is not what it should be, they are waaaaaay safer than chains
those straps are what you want, and bigger clevis's than the one displayed deff need recovery points braced into brackets i used 3 30 foot straps hooked together to get me out the other night most of all, you need a big deisel recovery truck on stand by, my come along didnt do anything when i was stuck in the mud
decent, keep it up noticing you don't have any putty glaze in the pics, youll need that to blend the bondo can't wait to see more -
Swapping In A 4.0/5 Speed
MancheKid86 replied to TheDude's topic in MJ Tech: Modification and Repairs
find a 4.0L an put the ax 15 in, need pb74 (input shaft pilot bushing) and its a direct swap, swapping in a 4.0L is alot work, all new components, harness, computer, welding new motor mounts, if your doing the 97 int. swap, why not do the whole conversion? -
Power To A 91 Mj Fuel Pump
MancheKid86 replied to Tom Tom's topic in MJ Tech: Modification and Repairs
take a wire, hook it up to the engine bay ground, and hook the other end up to the fuel pump ground, should fire right up, had the same issue when i took my 89's bed off
