Everything posted by MancheKid86
Fuel Pump won't Stop Priming
MancheKid86 replied to MancheKid86's topic in MJ Tech: Modification and Repairs
where would i find said relay? -
like above, noticed the engine idling at 1000 rpm latley, didnt think much of it then i turned the key over but didnt engage the starter, the fuel pump didnt stop pumping, any one know whats up?
yes genovast thats what i meant :P :rotf:
agreed,, must have pics
sounds like your pilot bearing is wearing a bit on your clutch fingers, it should go away, if you think its your clutch slipping stop on a hill and put it in 1st, if your clutch is strong you won't lurch back, if its slipping youll roll back down so be ready on the brakes I'm not too sure about the reverse issue tho
My 91 Comanche...sold Once And Now Mine Again!
MancheKid86 replied to a topic in Member Projects: Your Comanches
i like your dolly work on the corner! come do mine! welcome to CC! keep up the good work -
Teenage 1987 Comanche Pioneer Build
MancheKid86 replied to Tylerzap's topic in Member Projects: Your Comanches
holy man, what happened from the first pic to the second? and it looks like you have a project that will teach you alot that being said, you do realize you have the rarest interior known to a MJ? keep up the work, and lots of pics! btw welcome to Comanche Club! . :MJ 1: . :rock on: -
Alignment After Lift
MancheKid86 replied to JeepComanche89's topic in MJ Tech: Modification and Repairs
i ran a stock drag link on 4.5" of lift, i added a zj v8 tie rod which is a great upgrade and was cheaper than getting TRE's -
Where I'm living up north for school I got quoted 150-275 for a used front driveshaft, Down south where I live I rebuilt it to new for $150 xD At my pnp they are $20+tax
Looking good! Keep up the work! I just did that repair not to long ago :P
- 24 replies
- xj dash
- mj restore
(and 2 more)
Tagged with:
Tires And Gears ??????
MancheKid86 replied to Guanaco.13's topic in MJ Tech: Modification and Repairs
I'm running 35's on 3.55 gears, great for highway economy, Okish for wwheeling, 33's on 3.55's should be no problem, Go to 410 if your looking to do a lot of trail riding, It will have worse economy on the highway tho, because the amount of exyta rotations for the tires to go the same speed -
86 4X4 2.8L External Clutch Slave
MancheKid86 replied to captainkettel's topic in MJ Tech: Modification and Repairs
if you can't get the top one, put a jack under the transmission crossmember, lower the x-member once all the bolts are removed, youll have easier acess after that, try a bunch of extensions first, because the x-member bolts are usually seized to the frame -
My Badass Metric-Ton Comanche Build! (The End)
MancheKid86 replied to MancheKid86's topic in Member Projects: Your Comanches
No hangar brackets mounted to it sir, So when my axle contacts itt'l lift up with the axle, It was something I put together in 10 mins, just so I could get my truck ready for a 12 hour drive upnorth to complete my aircraift maitenance schooling, And yes I know its not 4x4 practical, just somethig to get me goin when I get back home I plan on adding a bend over the axle -
Canadian's Comanche, let see your truck and location !!
MancheKid86 replied to Red 1989 MJ's topic in Canada
I'm suprised that I haven't posted here, This my manche, I'm currently in dawsoncreek bc, but live in winfield bc, and probsa movingto osoyoos bc in feb -
You'll get it, I've been wtaching this build since ya first posted it, Keep er comin your doing great!
For your cruise control, The rest of the sensor needed is attached to the back of the of the gauge cluster, So you will need that, It pretty much taps off your spedocable, which the spedocable will plug into, Once you have that and the rest of the wiring from that sensor nstalled it should work, keep it up! :D
89 Comanche 4x4 build - university budget
MancheKid86 replied to 89Comanche4x4's topic in Member Projects: Your Comanches
If you have no luck finind a leaf pack, Get a set from hellcreek, comanche club gets a discount -
There's notHing wrong with the canadian army, They are peace keepers, for other country's where their armys have exponential ego's, Just sayin..
Can't Get Renix To Fire
MancheKid86 replied to diablo8511's topic in MJ Tech: Modification and Repairs
May sound weird, Maybe vapour lock from a leak in your fuel line/TB? -
Welcome baCk! Now let's see some updates in your build threads!!
LS1 MJ PROJECT... UPDATE!!!!!!!
MancheKid86 replied to GaruMJ's topic in Member Projects: Your Comanches
that sir is the 2500 conversion, don't think it is longer available, the dude who built that truck was selling the packages for just over $2000 iirc, and rmontes, that is a sticker, jeep converted thier emblems into peel n stick a while ago, but money talks I'm sure u can pay a company to make one :P -
Pictures In Preview/post Editor
MancheKid86 replied to MancheKid86's topic in Forum Issues, Ideas, Testing
Thanks! :D -
Thanks guys! more pics, look my seat bolts in! an upgrade to the one little 3/8th stud that held my seat on! sadly no more auto recline feature tho while doing hill climbs the said surface rust, ima pick up a can of rust killing primer to stop it before it goes intergranular here you can see the ammount of "massaging" that is needed for the new floor pan to mate to the old pan nothing like a big hammer and lots of tack welds the passenger side, looks much cleaner because the lack of salt + snow XD i also got around to installing my exhaust, i had everything i needed for the longest time, decided that welding wasnt nessicary and used a bunch of u bolts, i stretched and snapped the initial bolts to ensure a tight seal of the exhaust pipes, and boy what a difference actual exhaust is. my blower motor died on me on the way up to dawsoncreek, i got a new motor, assembled it and its installed now, no pics tho, but the heated cab is luxury :D more to come :P
