Tylerzap
    Asheboro, NC
  • Interests
    Jeeps
Tylerzap's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. A set of D44s from a 80 Waggy with manual hubs are also available to me, still in the Jeep. Plus cost of brakes, regear, mounts and everything.
  2. So I've been looking into performing a full axle swap on my 88 MJ. Plan is DD (most of my trips are 3 miles or less) with 33/35s while being able to tow and trail ride. I have a few HPD30s, an 8.25 sitting in my garage with ZJ disk brakes. All 3.55, would have to get them regeared to 4.88s, and do the WJ knuckle swap on the D30. There's also a sleeved, trussed, JK D30 for sale with chromo shafts geared to 4.88s locally for $700, and then getting a 65 wms rear axle and have it regeared to match. I don't mind fab work. Wanted to know what yalls opinion was?
  3. Bump. Checked everything. I'm lost. And since I swapped the flashers with my other Comanche, my hazards aren't working with a known good flasher. Diagrams aren't helping much either
  4. Any suggestions anybody? Can find anything that looks wrong. It's been very frustrating.
  5. I haven't had much time to mess with it since it happened, just a few minutes here and there. But after moving the brake light switch wires and a black/yellow wire connection last night, the turn signals no longer cut on when I brake. And as I said EVERYTHING else functions properly including hazards. So now my only issue is, my signals not working at all. Will try to get some pictures up soon
  6. Alright so while digging around, I found its either the brake light switch wires near the connector, or the back/yellow wire. I'll mess with it more tomorrow AND yes it has trailer wiring
  7. Thanks for yall's help so far. I went to take care of those wires. It is a total of 6 wires and they are all pink with no stripe and do run in the factory harness. Not getting power to it when I press my brakes with my test light or when turning on lights/blinkers, ect. So I belive it rules that out as being the problem. My turn signals are non functional from the stalk, however my high/lows wipers work. My Hazard lights are functioning perfectly.
  8. Right!? It's definitely not an issue I have faced before. I'm assuming that where they hooked the wire to kill the cruise, when brakes are pressed, is contacting somewhere it shouldn't but I'm probably wrong. As far as the switch itself on the column, I do not believe I did anything to it or messed with any of its wiring.
  9. Yes the front markers areally coming on. Nice and bright. Dash lights come on too. I will give the bulbs a try, however it seems to me the issue is related to how they had the unit wired as everything was working fine just before I disconnected the system
  10. The only odd thing I've found so far. This is the main harness behind the cluster, far drivers side almost behind headlight switch. Was wrapped in electrival tape and didn't look factory to me
  11. So yesterday I removed the aftermarket cruise control from my 88 MJ 4.0 5 speed. Appears to be a older Audiovox unit, although I couldnt find any markings. Took the unit and associted wiring out, didn't mess with/cut/unplug anything non relating to the system. Now when I hit the brake petal, my turn signals light up solid. All of them. Can anybody point me in the right direction of what to check? I just don't know where to start and couldn't find any info though searching. Thanks
  12. Alright I will give it a shot.
  13. It has brakes (not great but all 4 will lock on dirt), they will not build up with pumping, and no feeling whatsoever. Soft petal. Calipers are on right side up and I bench bled the master before I put it on
  14. Left the original line that runs from the front of the combo valve and plugged the failsafe at the bottom of the combo valve. I ran new line behind the gas tank to the rear softline, about 1.5 feet. Brakes weren't great and then they just kind of "let go" one day and I've been trying to track what happened. Nothing I have already replaced has made it worse or better. There has to be a hole somewhere right? I just can't find where.
  15. So i have a 1988 comanche 4.0 Brakes weren't great when I bought the truck, replaced a leaking wheel cylinder and bled. Brakes didnt completely go out but lost all pressure one day. So far, it has brand new: Wheel cylinders Brake shoes & pads Hardware kits Front soft lines Front calipers (2) Master cylinders I have also deleted the height sensing valve, and ran a new straight peice of hardline to the rear softline. Got rid of the failsafe line and plugged it. all brake lines are clean and rust free I bleed rr, lr, rf, lf No matter what I do they don't get better. I have used a solid 3 gallons of brake fluid through all this, bleeding the lines so much as needed, and there are no leaks. Only original parts are the booster, which is working fine, the hardlines from the master to the combo valve, and the ones from the combo valve to either front wheel. Like I said, no visible leaks and I have brake cleaned and searched alot. When you press the petal, it doesn't have any pressure against your foot. Like stepping into a bucket of water. But the brakes are working, just not at full capacity, will still lock all 4 on dirt. Help, please.
