Everything posted by MancheKid86
started gutting one, part by part, and chasing electrical gremlins in the other, insured it today replacing the front D44 wheel bearings tomorrow
Front 9 coil lift short arm, Control arm brackets were custom made to allow for 9" of lift, Scout II dA44 front Rear Soa with extended shackle for 9" 3/4'liptical setup (leaf pack bolted to the frame and other end of shackle)
can't wait to see the builds, when i first joined CC i loved your 3800 right off the batt
i don't see no 5.9l cummins? :brows:
nice trade, i wouldnt mind a j series truck to romp in
Because thats what they hit first while trying to guesstimate how much more room they have while backing up
- 5 replies
- For Sale
- Craigslist
(and 1 more)
Tagged with:
Replacing Shocks. Seeking Advice/tips.
MancheKid86 replied to MinnesotaManche's topic in MJ Tech: Modification and Repairs
get bilstien 5100 series shocks, worth the extra buck the upper shock mount in the rear is the one that will break, heat the nut, and freeze the stud, and tighten first then loosen, slowly loosen/tighten this will remove all debris off threads without binding and snapping the stud off when you install the new ones, the metal crush sleeve is not installed on the rear shocks it does not fit over the existing studs- 25 replies
- suspension
- shocks
(and 2 more)
Tagged with:
1988 Mj Random Misfire On #s 1, 2, & 6
MancheKid86 replied to Oyaji's topic in MJ Tech: Modification and Repairs
i just found my misfire on my manche the day it ran me over XD the plugs had bad shielded wires and was jumping from the wire into the block instead of the spark plug -
Forrest Green Pioneer
MancheKid86 replied to MancheKid86's topic in MJ Tech: Modification and Repairs
it was like a dark emerald/forrest green, with alot of metalic flake, it came with the pioneer, in 91/92 iirc keep em comin, still lookin -
Hey, looking for pics of the saught out dark metallic forrest green pioneer As well as the paint codes for it as well, Once I do the body work thats what the new mj is gettin
To Stroke Or Not To Stroke... Like Thats A Question
MancheKid86 replied to MancheKid86's topic in The Pub
Its cheaper and faster to do it this way, Body work and paint will only cost the consumables, I do body work on the helicopters for my work and my work has 2 60 ft paint booths, Too much work, the otherway, this is not a bolt in mod -
thia ia what it looks like now, not as pretty, but I'm going to do all the body work to it and paint it, and before it was trashed, after its straight and painted its gonna look great -
The last owner was not gentle on the body, So I'm going to have to do bodywork and repaint, But I'm buying it because of the parts, it doesnt look as nice as those pics -
its official, I'm in the stroker club, more pics on pickup Axles -Front and rear Dana 44 axles from an International Scout II. -Detroit Lockers front and rear with 4.09 gears. -4340 chromoly Yukon axles and super u-joints!! (CTM style) -Superior Alloy axles in the rear. -Warn premium hubs. -Rear disk brake conversion. Motor Transfer Cases and Transmission -Stroker 4.5L HO , multi-port fuel injection . -5-speed manual AX-15 from 1990 Jeep YJ. -External slave cylinder conversion. -Dual Transfer cases (116 to 1 crawl ratio). -1st: custom based on NP231 planetaries. -2nd: custom based on a combination of NP231, NP241 parts. -Front drive shaft is made from ¼ wall tube Suspension -Front Suspension is coil with 9 inches of lift. -Rear Suspension is spring-over with custom leafs (9”) - ¾ elliptic setup with lockout pins for street use. Other Mods -Beadlocks with Super Swamper TSL/SX 36" X 12.5". -On-board air, tanks under the box, couplers in both bumpers. -Warn 9000lb winch. -Custom front and rear bumpers. -Set up for rear winch, mounts under box, fairlead incorporated into rear bumper. -Box bobbed 10". -New Knack tool box -Heavy-duty GM cross-over steering. -Built-in rock sliders under doors. -Bosh 8" rally lights -MP3 deck, amp and 12" sub looks like I'm gettin an upgrade boys
Comanche Coulda Killed Me, (Some Pics Not For The Weak Stomach)
thats the plan, I'm also looking at a 2wd manche for 300, plus the other for 1800, so hopefully soon ill have all 3 -
My Badass Metric-Ton Comanche Build! (The End)
MancheKid86 replied to MancheKid86's topic in Member Projects: Your Comanches
so sat night i was about to hop into my comanche, i don't have the greatest parking brake so i chock my truck on the sloped driveway i have so i removed the chock, and the truck jumped 1st gear and took off, sucking my leg under the tire, it drug me 20 feet down my driveway, at this time i was freed from the truck, and it continued to roll down my drive way, off the edge, and flipped over 12 feet down to the road i was laying on my driveway for about 10 mins screaming my lungs off before my neighbors found me, my neighbors who found me are an rcmp officer and a paramedic, so they had me taken care of right away, and my neighbor on the other side of me was a paramedic as well, so he actually took me in the ambulance to the hospital i removed a very decent portion of my knee, and had to have roughly 30 stiches to sew it back together, 20 interal 11 external, the doctors said it was just like sewing up a turkey after being stuffed, and that ill have one wicked scar the truck is written off unfortunately, but i am safe, nothing broken, just really soar, i could see my knee cap, I'm off work for atleast a month, and currently working out a deal on a new comanche, yes not even a full day later and i think i found a suitable replacement, I'm importing it from the states to canada, its complete to the way i want it, the only thing ill change is adding my bushwackers onto it and painting it, the paint i want is dark metallic forest green, and i will have the white pioneer stripe down the back, yes I'm bringing sexy back XD here are some pics of me and my truck i will have more of the truck probably tomorrow -
so last night i was about to hop into my comanche, i don't have the greatest parking brake so i chock my truck on the sloped driveway i have so i removed the chock, and the truck jumped 1st gear and took off, sucking my leg under the tire, it drug me 20 feet down my driveway, at this time i was freed from the truck, and it continued to roll down my drive way, off the edge, and flipped over 12 feet down to the road i was laying on my driveway for about 10 mins screaming my lungs off before my neighbors found me, my neighbors who found me are an rcmp officer and a paramedic, so they had me taken care of right away, and my neighbor on the other side of me was a paramedic as well, so he actually took me in the ambulance to the hospital i removed a very decent portion of my knee, and had to have roughly 30 stiches to sew it back together, 20 interal 11 external, the doctors said it was just like sewing up a turkey after being stuffed, and that ill have one wicked scar the truck is written off unfortunately, but i am safe, nothing broken, just really soar, i could see my knee cap, I'm off work for atleast a month, and currently working out a deal on a new comanche, yes not even a full day later and i think i found a suitable replacement, I'm importing it from the states to canada, its complete to the way i want it, the only thing ill change is adding my bushwackers onto it and painting it, the paint i want is dark metallic forest green, and i will have the white pioneer stripe down the back, yes I'm bringing sexy back XD here are some pics of me and my truck i will have more of the truck probably tomorrow
looking for a comanche, has to have a 4.0L doesnt have to be 4wd, i can convert it to 4wd in a day lets see what you got. my truck jumped first, and ran me over, drug me 20 ft down my driveway before i was free, and it then rolled atleast 12 feet down an embankment to the road below writing it off call/text me at 250-864-8372 for an almost instantaneous response, or post here and ill check back daily
Need a detailed, plus bare minimum removal guide Doing my heater core replacement tomorrow or the nextday Any tips would be appreciated
Does Vin Tell Gear Ratio? Or Any Other Clues
MancheKid86 replied to DaveB26's topic in MJ Tech: Modification and Repairs
there is a data tag bolted onto your axle diff cover, it will tell you your gear ratio -
Empty Post -
Empty Post -
Empty Post
