Wrz
1 Follower
Contact Methods
  • AIM
    Italiang4lif89@aim.com
  • Yahoo
    Wrzauto@yahoo.com
    Suffolk Long Island
  • Interests
    Jeeps, Impala ss
1295 profile views
Wrz's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. would have to be for a 1996xj since i did a obd2 swap
  2. been a while since any updates, but ive been lurking weekly. The comanche hasnt gotten better and ive changed just about every sensor with oem stuff. I finally narrowed it down to bad wires. Bought a 96 xj to do the obd2 swap. The plan is to take the complete harness from headlights to tail lights, and complete dash and swap her in. Been about 2 weeks and have the donor completely stripped and the dash and engine bay stripped on the comanche. During the process i found over a dozen duct tape splices in the engine and dash harness :doh: damn po's Got the engine harness just about finished, just need to redo a few grounds. Here are some pictures, but nothing too crazy Sad comanche stripped and primed for some paint Fresh paint, New bottle and painted bracket Donor during harness labeling ( before pic before i took it out stripped mj dash Was really hard to actually start stripping snce i put soo much time and money into her, but was usless not running right On a good note i did end up buying a new aluminum 3 core radiator, silicone hoses, dual battery harness, and have a few more goodies sitting in the shed and at the powder coaters stay tuned better pics to come this weekend
  3. Hey limeyjeeper that cover looks good, Did you cut the inserts for the roll bar or you order it like that? thanks
  4. Looking foward to seeing some pictures, been looking for one for awhile as well
  5. Been looking for a spare jeep to drive while i work on the comanche 1998 Jeep grand cherokee 4.0 Came across this gem at my local auction, did not know much about it besides the pictures on the site and that it ran Looked it over in person and it was super clean under and inside besides a saggy headliner. Not a drop of rust anywhere Ended up winning it for a total of $1525 with fees and tax ect Picture from iaai site The main reason why i bought it As soon as i got it, it would overheat in gear only and i had no heat Few hours later i found the culprit Now runs great and have heat Also changed the front & rear sway bar bushings and rear end links Thats pretty much it for now, Waiting on my new shocks and some other misc parts to arrive
  6. no real updates, the Comanche will be down for a few weeks while i do a obd2 swap on it. Been having some wiring issued and figured i will as well do the upgrade. Here's a picture from yesterday of my mj that conquered the 2+ft snow with ease will have more updates this weekend as i start the tare down
  7. :thumbsup:Thanks appreciate the response, just wanted to confirm
  8. bump anyone :dunno: before i pull the trigger and buy it
  9. Well my comanche has been giving me problems for the last couple months, After countless hrs of trouble shooting and changing parts ive been debating on swapping out the harness. I found a great deal on a 96 xj that would serve as the donor for the interior and engine harness Parts already installed on current setup 1990 lwb pioneer 4.0 aw4 1996 xj head 2001 intake and throttle body 1996 manifolds 96 booster I know i will have swap the fuel pump and most of the sensors ect My question is will i have to change my fly wheel, and will i be able to still use my aw4 trans and np231 t-case ( renix error ) if i swap over all the electrical, computers ect? I know this will be alot of work doing the swap, but do not want the renix set up anymore thanks input would be great thanks
  10. in the process of gathering some parts to convert to mj in the spring to obd2, I have access to just about all the other parts, or have time to find them except the pump assembly Has to be for a 91-92 jeep comanche with a lwb Working or non working is fine since i will be sending it out to get refurbished if you have an extra or are willing to part with one shoot me a pm paypal ready
  11. not much to update on, still getting my @$$ kicked by the jeep. can't figure out why its running super rich. I have collected a decent amount of goodies over the last few weeks for it After getting my license plates stolen i decided to get some custom ones, and used some led bolts to secure them shot with the lights on going to get the exhaust moved towards the right more so its not right under the plate got my sliders in a few weeks back and finally had some decent weather to get a coat of primer on them hopefully we get a warm day over the weekend so i can get some paint on them Also have a superwinch, dual battery wiring, new rocker switchers, and some more misc items that need to be installed more to come soon . :MJ 1: .
  12. Thanks I changed and tested the map, changed and adjusted the tps, the only issue I have now is a high 2200rpm at start up, and it seems to idle are 900-1200. Running rich and still loosing 100miles to a tank, but I, pretty sure the injector is the cause of a few of those issues
  13. Just saw this post now and decided to check my gauge on the fuel fail. I clicked the key forward ( did not start ) and the pressure was a 32psi. Within a few seconds the psi dropped and after a few minutes was all the way down to 0. :doh: wish i would have thought of this sooner before buying all these sensors, guess i have some spares for the future. Really appreciate it, now just have to try and get a replacement and figure which injector is the culprit.
  14. i can get the paint code of the truck tomorrow for you, Which underhood parts were you talking about?
