Pete M
Administrators
    114
Everything posted by Pete M
  1. one side came out clean, the other cracked a bit but I still took it. I tried mightily to get the rear window trim but whomever installed that window used waaaaay too much urethane and it kept tearing apart.
  2. Pete M
    1J7FT36S2ML535943
    one last snap shot. the floors were pretty dang nice.
  3. I thought about that but then decided that they should be simply adding flat steel to the area instead. grabbed the parking brake and fuse box and even the carpet (for reasons that befuddle me) what's done is done. I've taken all I can justify buying.
  4. trains. went across the country in a train once. it was kind nice getting to see the scenery but not have to drive 30 hrs. Die Hard 1 or Die Hard 3
  5. always with those negative waves... CB premium cable tv or 50 different streaming services
  6. Tiger. If I was a billionaire I'd be trying to daily drive that puppy Hiking or mountain biking
  7. Pete M
    NAXJA?
    I certainly hope it's just a maintenance thing. that'd be an insane amount of XJ/MJ knowledge lost.
  8. indeed. relearned that myself just a couple weeks ago. that's why it's so important to take a test drive and re-torque the rims after any procedures involving tire removals.
  9. rocks v12 or turbo v8?
  10. I already took the rears. doesn't look like it in the pics, but the fronts are kinda mangled. spare tire winch is also deformed (the rear bumper sorta... pushed into it a bit ) might still grab that though if I can get it for free. I'd never removed the vents before and they made a cracking noise so I stopped, but I read Dzimm's instrustions and will try again tomorrow.
  11. oh I will. got a fresh pack of super long sawzall blades can't have too many clean rockers stashed in the barn.
  12. once upon a time I built a similar thing out of wood beams. loved it! except for it didn't move. it was just in the garage. I had to lift the engine up and then push the whole truck backwards. lol. I need to make another, but like yours
  13. better safe than sorry. never hurts to add more steel to a 4x4
  14. looking forward to seeing that! not everyday that someone has a seat fabbed up by their grandma
  15. it lives!!!! but yeah, 200 rpm is not a great idle speed.
  16. I mean, that sounds like a fun project but it also sounds like it'll be in the barn for maybe quite a long time?
  17. anything special about the HO MJs that I'm forgetting? It feels like I'm missing something. something that's unique to the 91-92s. I got a pile of the usual stuff but made sure to snag the fuel pump and the headliner. the engine was already gone and the wire harness was hacked apart dash harness was cut up when someone pulled the cluster was a 2wd auto column shift but the column was seriously jacked up. the whole thing was rotated to the side I think I might try and pull the carpet. I'm definitely going back for the rockers and a couple other little things.
  18. I think I'll just start naming them with their number. I think this is #8? been in an accident but the passs side is mostly fine and it's, of course, rust free.
  19. last I checked it's made of steel. just apply more as needed
  20. you're well on your way to perfect floors I'd probably cut out the frame cap because rust will continue to tear things apart underneath.
  21. Pete M
    1J7FT36S2ML535943
    less and less left each day. going back tomorrow for the rockers after I charge all my batteries. that drivers door was a super pain to get open.
  22. Pete M
    1J7FT36S2ML535943
    there's truth in your words.
  23. if something is going to fail, please let it be in the driveway.
  24. that bites
