Pete M
Administrators
    114
Everything posted by Pete M
  1. Pete M
    Overland MJs
    I gotta get around to making something like that for the Liberty. the current plan of "wrapping the top of the door in screen and rolling down the window" works ok at night, but the entire concept makes opening the door during the day quite difficult because the screen keep falling down.
  2. Pete M
    Overland MJs
    I've got buckets and yet still managed to spend more than my share of uncomfortable nights in the cab. are those holes individually screened? or are they to keep out those Alaskan mosquitos?
  3. are you contemplating a new project?
  4. looks solid
  5. gotta get me one of those someday.
  6. those are the little plates that hold the studs. (those are XJ though, which are same in the front but different in the back) I used five 1/4"-20 SS bolts (with fender washers) on each side to put the flares back onto my trailer. works just fine.
  7. are you referring to these?
  8. quick, someone compile everything into a spotify playlist!
  9. I made one too from a cut-down torx (I have a whole box of 40s) I have an 8mm socket on a mini breakerbar to start 'em.
  10. 30 inchers and 235s will fit no problems. 31s can fit with some caveats (namely the stock rims aren't all the same, and 31" tires aren't all the exact same size) some tire rub is possible on the lower arms (can be fixed with WJ lower arms)
  11. does it match the curve of the cab?
  12. is it weird that I now want to build up an MJ as a 2-tone Laredo on one side and a Pioneer on the other?
  13. google online driveshaft places like denny's or adam's. they should have instructions.
  14. it is not advise to have a shaft extended due to the challenge of re-balancing. but you can have your ends lopped off and welded on to a new tube. all depends on what you've got in your area for a driveshaft shop.
  15. are you saying you bolted the topper directly to the bed?
  16. don't even bother trying to cut out a floorpan. regardless of the ethical problems with hacking up a perfectly good body, it's simply not worth your time. the floors are held in by a million spot welds and you can get a perfectly good result from just flat sheetmetal. it's all going to be covered by carpet anyways.
  17. it certainly is unique
  18. a couple CC members were looking into printing up new ones, but I don't see any for sale yet so I don't know where those projects may have stalled.
  19. Pete M
    Minitrucks
    awesome!
  20. nice my sis just bought one just like it.
  21. it's been like 16 years now, but I still remember a point while building my 88, getting it on rims, and wondering if I may have screwed up and it'd never get out of the garage once on rubbers. it fit just fine, but it was closer than anticipated.
