Pete M
Administrators
    114
Everything posted by Pete M
  1. Pete M
    1JTWW6672GT222921
    how many factory leafs in the leaf pack? 3+1 is standard. 4+1 is MT for 86. theoretically the dana 44 wasn't available yet though. the AMC-20 was the heavy duty axle for 86.
  2. what was its performance before?
  3. while the engine is runnning, the pump is on continuously. if the engine is off, the key turned to "run" should have the pump fire up, then shut off once pressure is reached. if the engine is off (and you've disconnected the starter for these testing purposes) and the key is turned to "Start", the pump should run continuously. if I remember it right.
  4. yup, thems the ones.
  5. how similar is the 2.5L harness to the 4.0 harness? are they available new still?
  6. Pete M
    1J7FT36S4NL136937
    FT should be a 2wd, I was just hoping to confirm since my book only does 87-90 and this is a 92.
  7. totally worth a grand
  8. find a glass place that is willing to put in the effort. if for no other reason than to know where you can go in the future for quality work.
  9. I'm putting together a playlist specifically for the Durango's upped sound system. basically songs that need to be blasted to take advantage of the bass. some are obvious, others are less so. this one definitely made the cut. Live has a ton of good stuff.
  10. probably for the better. I guess an argument can be made that a water proof roof is a little more important than a new old jeep. not by me though. but I can see someone able to argue the point.
  11. Pete M
    1J7FT36LOLLI6I7I3
    so I'm going through and editing them. some are 2wd trucks, but others are 4wd trucks. the code always spits out "elect shift on the fly t-case".
  12. Pete M
    1J7FT36S4NL136937
    @500 MJ is this truck 2wd or 4?
  13. skip that. looking up the VIN in my parts manual, the T indicates a 2wd.
  14. that's something to look into for sure. that code could be a reused that used to mean 2wd but now applies to something else. technically it used to say "Electric shift on the fly" and I edited the electric out. please report back with what you find. I may need to re-edit a bunch of entries. lol
  15. yes and no. the codes above are all yours, though the meanings may have changed over the years because chrysler reused codes. I've gone through and edited out the most common ones (for example, you don't have a "Mopar hood lock", the code JKBS likely applies to an internal hood release handle and chrysler reused it for later wranglers). the other issue is that there was apparently a flood in the records room (at least that's the story we hear) and not all of the codes got entered into chrysler's computers. if you look around at the various years, older years have way less codes pop up than newer years, when in reality they should have similar lengths of printout. errors may still remain (like the hood lock since I missed that).
  16. that's an expensive wall for sure, but sooooooooo worth it....
  17. Pete M
    CC cookbook
    tonight i made a cup of Minute rice (chicken flavored), Ikea meatballs (quartered), and a dab of sweet and sour. tasted pretty good, actually. follow me for more I-just-don't-feel-like-cooking-tonight recipes.
  18. might be time to pull the pump and make sure it's all together. did you change out the fuel filter?
  19. what's the end goal?
  20. time to get on that. fresh oil can make a world of difference. it takes a weird square metric bit to undo the plugs. I just took an old 3/8" ratchet extension and filed it down a hair so it'd fit. be sure to undo the fill first, then the drain. that way if you have issues with the fill plug, you aren't stranded with a trans with no oil.
  21. the link in my signature might have info on that. there are several swap threads down in "Systems conversions"
