So I did take off the fuel pump and tested it at the wiring harness to see if it would work connected to a battery. Sure enough it did not do its job. However I did check everything else everyone listed, and sure enough, those were ALL issues I had. Lol. I found out this poor guy sat for about 15 years total. Within the last 5 years it had a new timing chain, new head gasket, ECU replaced, new distributor cap, rotor, and spark plug wires, that new fuel pump 2 years ago that went bad, a new gas tank, new fuel sending unit, a new clutch, and the front diff was rebuilt supposedly.
Now, that being said, in edition to the fuel, I have another issue, the brake pedal goes to the floor. It has some pressure, and sounds like when you push on the pedal air is being pushed somewhere. I've never had that happen before so I'm not sure if that would be the master cylinder or brake booster, but I'm fairly certain it's not a line. Any advice on which one to go for?
Attached will be a picture of her, and my vision for her in case anyone wants to stick around for the journey. Lol
