Gjeep
3
Everything posted by Gjeep
Who here has headers on their 4.0 liter
Gjeep replied to KANTANKRUS's topic in MJ Tech: Modification and Repairs
I’ve always run Borla no issues. My 95 xj I bolted a borla up when it had 15,000 miles and ran it to over 525k on the original engine. Borla’s on my MJ strokers as well. No clearance issue with the newer intake. -
Seams/ gaps in the sheet metal of the floor board. Or rust holes if you are in that part of the states. I’m in CA and both my MJs when I coated the floor boards (to seal them up) drip dripped the POR15 coating on the floor below through unsealed factory gaps in the floorboard.
Red Mistress I know is looking for a SB fuel skid
The plastic trim was 86-90. 91/92 had no trim around the light.
Jeep Wrangler tires on a Comanche
Gjeep replied to Inventorben's topic in MJ Tech: Modification and Repairs
FYI, your truck is an 89 MJ from the color/ stripping. -
In for HO buy also
No MJ's came with a rear sway bar from the factory. PST (Performance Suspension Technologies) originally made the MJ aftermarket rear sway bar for the short bed only. Addcco purchased this design and now sell it as their own. The bar is nice and beefy but the linkage set up is ridiculous. Has 15" endlinks stacked with 8-10 small bushings on each side that secures to the upper shock mount. I'm sure other endlinks can be used, I just didn't want to deal with it at the time.
As you know, fronts are the same. Rear is different.
I bought the sway bars at SD Springs about 3 months ago.
Yep. A '98 XJ Classic only item. He upgraded them years after buying my '97 Sport. These icon rims were bright silver in later XJ's.
So cal truck. Poorly repainted. Bent rear bumper... pricey. https://www.autotrader.com/cars-for-sale/vehicledetails.xhtml?listingId=519554014&zip=95120&referrer=%2Fcars-for-sale%2Fsearchresults.xhtml%3Fzip%3D95120%26sortBy%3Drelevance%26incremental%3Dall%26firstRecord%3D0%26marketExtension%3Don%26modelCodeList%3DCOMANC%26makeCodeList%3DJEEP%26searchRadius%3D500&numRecords=25&firstRecord=0&modelCodeList=COMANC&makeCodeList=JEEP&searchRadius=500&makeCode1=JEEP&modelCode1=COMANC&clickType=listing
Picked up this ’97 XJ 2wd several months back and it has moved in front of the MJ builds for now. Super clean, low mileage…bought from a 90 year old retired air force mechanic. Spent more than I wanted to but couldn’t pass it up. 4.0L AW4 LSD 8.25 axle. I’ve currently pulled out the ‘97/’98 year only saddle color interior that I found hideous. I’ve been collecting as many NOS agate (charcoal) interior parts and panels as I can find and I’ve just about got them all. Will be installing ’01 XJ new power heated seats, fog lights, extended idle control, overhead console, etc. All the bells and whistles on the inside. For the exterior, I’ve already torn apart/ modified the front and rear suspension with 1” lowered heavy duty custom coils, add-a-leaf, beefy Addcco bars, KYB shocks, and new brakes/ cross-drilled rotors up front. I’m running powder coated black TJ Ravine rims wrapped in big and little BF Goodrich Radial T/A tires (255/60 front; 275/60 rear). New Mopar/ Jeep bumpers and body trim have arrived and all the old stuff removed. Will be updating the body badgeing to the brushed chrome of the ‘00/’01 XJ Limited era. And the 4.0L engine is getting the later style U-shaped intake manifiold, Borla header and cat-back exhaust. Should be fun once I’m done as a semi-daily driver.
Clean install, looks good.
- 657 replies
- 2.5litre hurricane
- pioneer
(and 2 more)
Tagged with:
For Renix era guys, this truck has the dealer installed A/C. I purchased this kit myself and sold it to someone on CC. Any way, there’s an engine pic in this ebay listing. The dealer kits are visually unique because of the the clear plastic sheath on the line off the compressor. And the 2 piece lower radiator hose that has the temp sensor that kicks on the Efan. Check it out, clean truck too. https://www.ebay.com/itm/1987-Jeep-Comanche/123890936241?hash=item1cd879a9b1:g:VWEAAOSwAy9dOmbt
Nice looking XJ. The chrome also came on the 00/01 xj freedom model.
That was for a Comanche short bed. I owned one but didn’t like the 12” stacked end link bushing design. I could never keep the nut on top tight. Again it is MJ short bed specific. I sold it to Don who learned it wouldn’t work on the long bed.
91 Eliminator 83K miles refresh with NOS parts
Gjeep replied to Red Mistress's topic in Member Projects: Your Comanches
84-85 XJ's (some early '86's) had the black metal door handles. -
My MJ has been sitting for a time as I've been working on getting an overhaul on the house done. In between working on the house, I've found a low mileage mint condition flame red 97 XJ that I've torn apart and am redo-ing in depth...BUT as I work on other projects, the MJ is never far from my mind. Since the Hesco stroker was installed I've only run it basically around the block a couple times. It runs hot as it is apparently known to do until it breaks in. Since the Reflexxion cowl hood is not longer available and I'm not a fan of the fiberglass variants, I've been trying to find a tasteful hood louver option. I've purchased several sets of the '90's Pontiac Grand Prix GTP louver, but wasn't 100% sold. Finally came across MMD's Ford Mustang (functional) louver/ vent, part# 71334-99. I took a chance and bought it to place on the hood. It looks good and can be placed in a location with minimal affect to any under hood electronics. I've yet to cut into the hood, but plan to before end of summer. Here's a pic of the louver set. I'll most likely use these same part#'s on my '89 MJ stroker project as I like the look of them. Stay tuned for installed photos...
90 2WD Eliminator, Ventura, CA $6500
Gjeep replied to NHMJXJ's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
I remember this truck was for sale back in 2011-ish. It was towed behind a motor home. It was between this truck and the 92 MJ I ended up buying. This is a clean truck and I’m glad to see the second owner didn’t screw it up. -
I don't think any street comanche's were lowered from the factory.
