27
Everything posted by Eagle
Money. I know you get what you pay for, but OEM was $225 and Auto Zone was $50. I didn't have $225 (plus tax) to invest in a track bar when I needed it.
Rear XJ bars are tiny. Probably not more than 1/2-inch. I have one out in the garage, but I don't feel like going out to measure it at the moment.So I guess I have to start looking for a couple of XJ Up-Country sway bars, or a couple of ZJ V8 bars.
I recently put a new Auto Zone track bar in my wife's 2000 XJ. It didn't do much to tighten up the steering, and it appears that the problem is the rubber bushing in the axle end is too soft, allowing the bar to shift slightly as it compresses the rubber. Auto Zone offers a polyurethane bushing kit for $10. Has anybody used a poly bushing kit to repair a front track bar? If so, how well or badly did it work? http://www.autozone.com/suspension-steering-tire-and-wheel/track-bar-bushing/energy-suspension-track-bar-bushing/354359_253661_5934
The factory parts manuals I have access to only show me two diameters for the front sway bar: 24m or 28 mm. That corresponds to 15/16" and 1-1/8". But when I go to Auto Zone and look up replacement "bushings" (cushions), they show me 7/8" (22mm), 15./16" (24mm), 1" (26mm) and 1-1/8" (28mm). How many sizes of front sway bar are there to fit the XJ and MJ? Does anyone know if a front sway bar from a ZJ V8 will fit an MJ? Are all ZJ sway bars the same diameter? I'd like to upgrade my handling a bit, and I want to go as fat as possible on the front sway bar. What are my options?
In the RENIX years, the ECU is behind the firewall, above the driver's right foot. And the 4-cyl only has one injector (TBI), rather than 6 injectors for the 4.0L. Like it or not, regardless of the C101 you're really looking at a complete harness replacement, not an engine-side only temporary swap.
I'm pretty certain you can't just unplug a 4-cylinder from the C101 and plug in a 6-cylinder. Obviously, the ECU is different, and I believe the pinouts are different.
As a certified instructor, especially for women I strongly recommend the NRA's Refuse to be a Victim (RTBAV) course. It's being offered all around the country, and it offers REAL (not gun-grabber) common sense strategies for keeping yourself, your loved ones, and your stuff safe. It is NOT about guns or martial arts. https://rtbav.nra.org/
MUCH less than $10,000. A conversion to 4WD basically involves exchanging the front axle for a 4WD axle from a Cherokee, and exchanging the 2WD transmission for a 4WD transmission and transfer case from a Cherokee. Nothing more complicated than taking any vehicle to a transmission shop for a transmission overhaul. Don't sell. The last Comanche was made 25 years ago -- if you have one that's in good condition, it would (IMHO) be foolish to think that you can sell it today and find anything comparable at some time in the future.
Try the thread file first -- or a thread restorer die.
Death wobble is getting old
Eagle replied to creep_in_the_jeep's topic in MJ Tech: Modification and Repairs
I'm well-acquainted with the 55 MPH shimmy. If you can drive through it until it disappears at 60 or 62 MPH, it's not death wobble, it's just shimmy. I've experienced real death wobble twice in my life. You DON'T try to accelerate through it, you hang on for dear life and pray you can slow it down before you die. Then you go home and throw your knickers in the laundry. It's called "death wobble" for a reason. -
I disagree. A properly balanced tire is a gyroscope, and it basically CAN'T wobble. A blown shock and/or a loose ball joint may allow death wobble to be worse than if those components were perfect, but they can't cause death wobble. -
Or swap the speedometers.
Some things "cause" death wobble. Some things "allow" death wobble. Balance your tires. Loose steering components do not "cause" death wobble. -
He said he changed the senders.
questions about belts, pulleys, and rear traction
Eagle replied to vandior2001's topic in MJ Tech: Modification and Repairs
A heavy rear bumper can help, but it also has a downside -- it's several feet behind the rear wheels. If you start to skid, all that weight is going to make it harder to pull out of the skid. You really want any additional weight right over the rear axle. -
MJ Load Sensing Valve Delete Procedure
Eagle replied to HOrnbrod's topic in MJ Tech: Modification and Repairs
There is no "return" involved in the MJ braking system. One line is the normal line that runs through the height sensing valve, the other is an emergency circuit that bypasses the height sensing valve if the front brakes fail. If you don't have the load sensing valve hooked up, you should not be running two lines. -
Without major trimming? For the lift you have in mind, 31x10.50
Center axle disconnect bushing
Eagle replied to 8valvehero's topic in MJ Tech: Modification and Repairs
I wouldn't call that part a "bushing." It doesn't function as a bushing, it functions the same as a synchronizer ring in a manual transmission. My '88 Cherokee has the disconnect axle. It's currently at 287,000 miles, and I've never touched the disconnect. Mine is currently still functional but I hope to get it back on the road for winter, and my plan is to set it in the locked position and forget it. -
Yes, AMC offered an overdrive at the time. As someone whose family owned and drove nothing other than AMC cars, and who hung around with the service manager from one dealership and the son of the owner of another dealership, I can honestly say that I've only seen ONE AMC car with a factory overdrive. That was my mother's 1964 Rambler station wagon. They offered it, but they didn't sell a lot of them. Well under 10% of the number of vehicles sold, and I'd guess it was actually more like less than 1%. They certainly didn't design the engine around the notion that all (or even most) customers were going to have the overdrive. The overdrive wasn't a transmission, it was a separate overdrive unit that mounted after the transmission.
According to the 2000 XJ FSM, 6:00 o'clock is the correct index. I would pull it anyway, and inspect the speedo gear for possible damage. Is the new gear the same length as the original?
The problem started when you swapped the speedo gear. Did you properly "clock" the speedo quill that goes into the transfer case? The orientation is dependent on the number of teeth on the speedo gear. Not sure, but I don't think 6:00 o'clock ids the index location.
AMC introduced the family of engines that eventually became the 4.0L all the way back in 1964. The nationwide move to reduced, 55 MPH speed limits didn't arrive until 1973 or 1974, when we had the first so-called gasoline shortage. Before and after the 55 MPH era, we routinely cruised at 70 t0 75 MPH, with the tach hovering around 3000 RPM or a bit more, and the engines lasted 200,000+ miles. Gas mileage was (and is) better below 60, of course, but that's a function of resistance when you're trying to push a brick on wheels down the road at speed. The engine RPM isn't the major factor in that. It's your money and your vehicle, but IMHO you're heading toward making a mistake.
I don't see a problem. The jeep I-6 engine dates to well before overdrive transmissions became the norm. "In the old days," AMC vehicles with standard transmssions typically were geared to run at 24 MPH per 1000 RPM in top gear -- whether that was 3rd gear for a 3-speed or 4th gear for a 4-speed. If you do the math, that works out to 2500 RPM at 60 MPH, and 3000 RMP gave you a 72 MPH cruise. Set up like that, they lasted a couple of hundred thousand miles with just routine maintenance, and delivered what was then considered excellent fuel economy. I should know -- I've owned a bunch of them over the years. IMHO 2700 RPM at 70 MPH is just about perfect. I don't see any reason whatsoever to spend a bunch of money "fixing" something that ain't broke.
We're at the alignment shop
Eagle replied to coolwind57's topic in MJ Tech: Modification and Repairs
A picture is worth a thousand words -- or a decimal point. :) Yeah, there's a wee bit of difference between 61 degrees and point-61 degrees. For what it's worth, the 2000 Cherokee FSM lists the alignment specs in degrees. Preferred is +.25 degrees, allowable range is 0 to .45 degrees, and the right-to-left difference is .05 degrees. So your .61 is indeed out of spec, and the left-to-right difference is also out of spec. That said, others have raised a good point -- with the lift, your axle is off center. They can set the toe-in, but ti's likely to still pull to one side. I would respectfully suggest using a tape measure to set your toe-in for now, and hold off on the professional alignment until you get an adjustable track bar so you can have the axle centered.
