lawmanbsi Posted February 5, 2008 Posted February 5, 2008 I have a doo hicky running down the thing-a-ma-jig. I'm not sure but I think the hootin peckers broke. what should I do. :bowdown:
Pete M Posted February 5, 2008 Posted February 5, 2008 Is it making any noise? Get out your left-handed whats-it wrench and tighten up the little metal thingie for now. You'll definitely need to replace your doodad in short order, but I think you'll be fine for a while.
joshmillslane Posted February 5, 2008 Posted February 5, 2008 that is, unless the doomaflatchie starts leaking...
lawmanbsi Posted February 5, 2008 Author Posted February 5, 2008 just nice to have so many people here to help out. thanks everyone
JeepcoMJ Posted February 5, 2008 Posted February 5, 2008 don't' fourget the atomatik peejnikufesin and whatnot
gixxerman600 Posted February 5, 2008 Posted February 5, 2008 might need to change your radio knob filter and check your mufler berrings.
mjeff87 Posted February 5, 2008 Posted February 5, 2008 had that happen on mine once, ended up being the kinipulator nut on the knockulator pin was loose. HTH, Jeff
Chico Posted February 5, 2008 Posted February 5, 2008 Yeah, well I've been looking for the last 13 hours and can not for the life of me find any of these parts in my FSM.
watchamakalit Posted February 5, 2008 Posted February 5, 2008 you're making me hungry for a whatchamacallit Sorry man I don't swing that way. :eek: :eek: Sounds like the cannoter valve might be plugged. Might want to flush it out with some mirror fluid and check the preload on the muffler bearings.
SuperWade2 Posted February 5, 2008 Posted February 5, 2008 you're making me hungry for a whatchamacallit mmmmmmmmmmmmmm.......
ComancheKid45 Posted February 5, 2008 Posted February 5, 2008 if that doesnt fix it add 1 can of compression to your oil, that outta help lube the piston return springs which may help the issue
LJRockstar Posted February 5, 2008 Posted February 5, 2008 Check these guys out.... They have everything! Even windshield wiper sharpeners! http://www.kalecoauto.com/ This is particularly helpful for the owners of automatic transmissions: http://kalecoauto.com/index.php?main_page=product_info&cPath=7&products_id=22
89eliminator Posted February 5, 2008 Posted February 5, 2008 don't forget to change your blinker fluid every 1,000 blinks.
CEThomas Posted February 5, 2008 Posted February 5, 2008 don't forget to change your blinker fluid every 1,000 blinks. This is NOT TRUE!!! I get 3,000+ blinks on a change. Used to get over 5,000 till the O-ring went bad and started leaking blinker fluid bad :chillin:
speed_racer Posted February 5, 2008 Posted February 5, 2008 Ah, the dreaded blinker fluid leak, I just clogged mine w/a tampon. Works great. Make sure you get the plastic applicator though, the other one caught fire! :eek:!
89eliminator Posted February 5, 2008 Posted February 5, 2008 don't forget to change your blinker fluid every 1,000 blinks. This is NOT TRUE!!! I get 3,000+ blinks on a change. Used to get over 5,000 till the O-ring went bad and started leaking blinker fluid bad :chillin: i change it every 1000 to insure a long life for the blinkers, plus i make my own fluid. :D
